LS1 A/C compressor... why can't I use it?
Old May 17, 2011 | 04:21 PM
glarior's Avatar
glarior
Default LS1 A/C compressor... why can't I use it?
Doing a LS1 conversion in a '80 vette. I know I can buy a bracket kit for the R4 style compressor. However, I wanted to use the one that came with the engine. I was told I can't use it.. is that true? All I should need is the lines run to the compressor and a bracket in my mind. Correct me if I am wrong...
Old May 17, 2011 | 04:23 PM
MrJlr's Avatar
MrJlr
There is no reason you "can't"...
Old May 17, 2011 | 04:24 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Were you told why you couldn't use it?
Old May 17, 2011 | 04:51 PM
glarior's Avatar
glarior
Not enough to understand why. They started listing off parts and prices. It went from a simple bracket mount to needing a compressor, bracket, tensioner and something else which I could not understand. Oh, also said something about the LS1 engine a/c compressor (from the camaro) is always on and the A/C lines will hit the hood
Old May 17, 2011 | 07:09 PM
72LS1Vette's Avatar
72LS1Vette
I know the compressor will not fit in the F-body location. Could be that nobody makes an adapter to mount it higher, and perhaps there are interference issues if it is mounted higher. I think Sanden makes a mini compressor that will mount high up and not interfere with anything.
My suggestion would be to sell the compressor and put the money towards a new setup.
Rick B.
Old May 17, 2011 | 09:13 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
I think it's the LS2 compressors that cannot be used. They are controlled by a separate computer in the original vehicle (Corvette and GTO) and will self destruct if run with just direct power applied.
Rob
Old May 18, 2011 | 05:04 PM
glarior's Avatar
glarior
Rob
I heard something about that....
Old May 18, 2011 | 05:09 PM
glarior's Avatar
glarior
Okay... what would I need to buy to have A/C in the car?
Sanden compressor and bracket? And is there another brand of bracket that is not 300 bucks?
Old May 18, 2011 | 11:00 PM
myoriginal77's Avatar
myoriginal77
There is no room at the bottom mounting location for the LS1 compressor in a C3. You can buy a mount that will mount the old style compressor like from a Camaro or older Corvette up higher from Josh - Superpowers over on the other site. I bought them for mine and have not used them yet but they look like the way to go.
Hope that helps,
Frank
To LS1 A/C compressor... why can't I use it?
