door won't open
Old May 21, 2011 | 09:26 PM
bbdude454's Avatar
bbdude454
Default door won't open
Was going to simple remove and replace the door locks on my wifes 74 all went well until I shut the door. The door won't open back up, handle is stuck half way down can't even open from the inside. The door lock is not feeling like it is engaging when turning the key. Not real sure what to do now, I would appreciate any help on trying to get this door open.
Thanks, David
Old May 23, 2011 | 11:06 AM
MCMLXXX's Avatar
MCMLXXX
St. Jude Donor '14
I had the same thing happen to me a few weeks ago when I went in to adjust driver side window. I finally got the door open, took the door panel back off and sprayed white lithium grease on all the moving parts of the door mechanism. and That fixed my door issue, driver door has not given me a problem since.
