1977 trailing arms
Old May 22, 2011 | 06:21 PM
ussjames's Avatar
ussjames
6th Gear
Default 1977 trailing arms
1977 trailing arms need rebuilt. Am i getting into something that cannot be done. I have access to presses, machine shops etc? there are some vendors that offer bushings installed in their deal....is that one of the problem areas for home rebuild?
thanks for any help
Old May 22, 2011 | 07:57 PM
RIO68's Avatar
RIO68
thanks for any help
Quick easy way is to exchange yours with one of the vendors for rebuilt ready to go back in. If money is an issue search out the many articles and self help info available here and give it a spin. Can be done at home just get the right info and go for it!
Old May 22, 2011 | 08:45 PM
markids77's Avatar
markids77
Bushings are a pretty straightforward repair, invest in one of the vendor's tools to assist the process. I bought mine used on eBay and resold it after use... even made a buck or so on that deal. E-brake rebuilds are a do it yourself deal as well. Rear bearings require more special tooling and a bit more resources... if you've ever set up a ring and pinion, that should be within your capabilities if you invest in the tooling. If not I might recommend you use your hubs as cores and get rebuilt units.
Old May 22, 2011 | 11:22 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
With the right tools it can be done at home, but they HAVE to be done correctly. No guesswork. PITA, but you can save $$$ doing it yourself.
Old May 23, 2011 | 07:17 AM
ussjames's Avatar
ussjames
6th Gear
thanks for any help
Let me rephrase quote....I need to replace the trailing arms. Installed trailing arm welds are shot. So my question is buying new parts...using what i can from this set-up. Is is beyond doing it at home. Bearing set-up tools and guide are no problem. Any suggestions on which Trailing arms to get...some claim to have bearings readily presssed in.
Old May 23, 2011 | 11:26 AM
garage-ghost's Avatar
garage-ghost
I have dealt with these people for 20+ years, good people. Google Bairs Corvettes
Old May 23, 2011 | 09:42 PM
battsup's Avatar
battsup
Let me rephrase quote....I need to replace the trailing arms. Installed trailing arm welds are shot. So my question is buying new parts...using what i can from this set-up. Is is beyond doing it at home. Bearing set-up tools and guide are no problem. Any suggestions on which Trailing arms to get...some claim to have bearings readily pressed in.
Willcox has trailing arms for CF members for $135. where did you see trailing arms with the bearing already pressed in?
Old May 23, 2011 | 11:16 PM
merc49's Avatar
merc49
i just exchanged my old ones for rebuilt units for $500 from the corvette guys in wisconsin.they are complete ready to install with new bearings and park brake.as long as yours are rebuildable they will be that price.
To 1977 trailing arms
