alternator size
Old May 29, 2011 | 07:26 PM
Wrecked82's Avatar
Wrecked82
Default alternator size
What is the best, least expensive alternator size for an 82 that has no upgrades in the power area? 63 amp OK? Mine tanked and need to replace.
Old May 29, 2011 | 07:53 PM
PeteZO6's Avatar
PeteZO6
Why don't you fix it yourself? Usually the internal solid state regulator ('69 and later) goes out; easy to replace, and pretty inexpensive. Other failure points are the diodes, brushes, and bearings. The entire unit is easy to remove, take apart, and put back together.
Pete
Old May 30, 2011 | 09:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Go with what came off of it. Over the counter at the generic auto parts houses. They will want your old one as a core.
If yours is original and you want to keep the date codes, rebuild it or have rebuilt.
To alternator size
