Does anyone know what the machined stamp pad codes are for 1971 LS6 & ZR2?
Would the ZR2 be the same as the LS6? I know that the ZR2 was an LS6 with other options.
Also what would the casting numbers be for the block and the intake?
Thanks.
Thanks.
I also agree with 66L36Coupe on his listed codes, which are for a Corvette.
Tho since the '71 Chevelle also was available with an LS6 (albeit lower compression for 1971 LS6 motors) the codes for the Chevelle 454 LS6 were:
They would be the same for LS-6 and ZR-2.
I found someone selling an original (according to him) big block 69 automatic and he told me that the vette has a nom and that the current motor is from a ZR2.
So it seems that the motor if it's a true 71 vette LS6 although still rare (188 made if I'm correct) there's no way to tell if it really was a ZR2 motor.
Assuming the vette is clean and mechanically sound, what do you C3 knowledge veterans feel this vette might be worth with this LS6 in it if it's a real vette motor?
Thanks alot for the info.
Reason: Assuming...
Give me a call, should you buy this car. I would be interested in any and all original 1971 LS6 Corvette engine pieces. There are several unique mechanical items that make up a 1971 LS6 engine. All would need to be present in order to verify whether the engine assembly you have in this '69 Corvette could be the genuine article. My phone number is (530) 265-5204. Call anytime.
