#4 Body Mount Nut
Old Jun 6, 2011 | 01:22 PM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
Default #4 Body Mount Nut
Almost got the body ready to lift off yesterday and ran into the ONE bolt that is holding me up The left caged nut on the #4 body bolt is rusted to the bolt and rounded off the cage. Anybody know what size the square nut is? I'm guessing at about 1".
AND, when I replace the cage can I just use pop rivets to fasten it or does the underneath mount need to come off to properly set the rivets?
Thanks.
PS, I'm in the market for a body lift sling if anyone has one....
Old Jun 6, 2011 | 02:18 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
cut the head off, and continue with your lift,
your not gonna reuse a rusted bolt anyway.
It is much easier to access and remove stuck bolt,
after the frame seperation.
Old Jun 6, 2011 | 02:58 PM
C2C6Z06's Avatar
C2C6Z06
69Vette, thanks for the direction....that was my first thought, but I hate the idea of a sawzall near fiberglass....
Old Jun 6, 2011 | 03:00 PM
GD70's Avatar
GD70
Cut it with a Dremel cutting wheel. Much smaller and more control. Make criss-cross cuts across the bolt head, then cut each section away. It may take a couple cutting wheel disks to do the job.
Glenn
Old Jun 6, 2011 | 03:21 PM
BBCorv70's Avatar
BBCorv70
Glenn
Been there...
So far as riveting the new cage in place, I think you'll need to remove the plate from the underside to access the heads, going from memory. I had to replace the lower pieces anyway. A pop rivet may hold the cage in place but I'm not so sure it will keep the nut from spinning in the future. I used the solid rivets as the factory did. They're a pain to peen over if you have a coupe, impossible to see. A Convertible may be easier?
Old Jun 6, 2011 | 04:13 PM
69Vett's Avatar
69Vett
another alternate bubba fix. after cutting head off from the bottom.
Slice the cage around the nut from the top inside the car, or drill out 1 rivet.
difficult but do-able, slice the cage retainer, peel back the retainer.
liftout old cut-off nut and bolt. drop a new nut into place, bend back the retainer..
it will hold for a new body mount bolt,
besides how many times would you need to remove that nut. in the future?
Use a cut-off wheel or a dremel, to avoid cutting up more work.
To #4 Body Mount Nut
