Question on fuel supply?
Old Jun 8, 2011 | 04:51 PM
...Roger...'s Avatar
...Roger...
Originally Posted by daanbc
By the way, is that what that hole was designed for? I see no reason that there would be a small bolt in the front of the block doing nothing/bolting down nothing? Also as I was un-bolting the second bolt from the pump, the pump itself was pushing out. (which tells me the rod is at the long run of it's cycle. Will I need to turn the motor so the rod flows/rides back in, to place the new pump on?
I don't think the bolt was put there for the fuel pump,I could be wrong but in earlier years I believe those bolts were used for the motor mounts.
The spring you were feeling is from the pump and no matter where the rod is you will feel that spring,you can reduce it a little by turning the motor until the rod recedes some if it is actually all the way out.
Old Jun 8, 2011 | 04:57 PM
...Roger...
Originally Posted by damoroso
Then you push the fuel pump push rod up as far as you can and tighten the new longer bolt
just enough to hold the push rod
If you tighten the bolt too much you WILL bend the pushrod and end up with a tick tick tick when the engine is running.
Thats why I made a tool that uses only the clean threads used by the short bolt that was in the block,this way I can hand tighten. I know a little **** but if you do a lot of pumps it pays for itself.
Old Jun 8, 2011 | 05:13 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Oh, the fuel line you can get from the vette suppliers, NAPA and the like don't usually have it. If you use regular fuel line, make sure you don't kink it with the bends necessary to get from the hard line to the pump. Too bad you're not closer...I have a new pump sitting in the garage I don't need anymore...
Thanks, for the offer, I already ordered one, and it will be at my front door tomm. I ordered a chrome one. I figure everything that I will be fixing, I might as well get it in chrome if I can. I already used a longer bolt (see pic with circle around it). I was just wondering why the original short bolt was there. It does not hold anything together. Just a hole with a bolt. So I assumed it was placed there for this reason. Anyways, you say to push the rod in all the way then tighten the bolt. But doen't the rod ride on a lobe on the cam shaft? If so, how can you push it in without turning the motor?
Old Jun 8, 2011 | 05:16 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Thanks!!
Old Jun 8, 2011 | 06:09 PM
Birdman's Avatar
Birdman
I've replaced my fuel pump 3 or so times...and never have had to turn the motor..
Old Jun 9, 2011 | 08:25 AM
damoroso's Avatar
damoroso
The rod does ride on the cam, but the lobe only has one high spot. Unless your engine is stopped right at the high spot, you'll have plenty of room. You can reach up into the hole where the fuel pump goes, and push the rod up towards the cam. You may have to use a screw driver if the rod has fallen all the way down (likely). Once you get the rod up, snug the longer bolt, slip the new pump arm under the rod, bolt the pump in place, and replace the longer bolt with the orignal short one (if you leave a longer bolt in there and it's too deep, it could hit the pump rod).
Old Jun 9, 2011 | 08:44 AM
...Roger...
You never "have" to turn the motor,the pump can be installed if the rod is on the high point of the lobe (or eccentric in this case I believe)but it is easier when its at the lower point.
