???? on my 81 ???
Old Jun 8, 2011 | 01:23 PM
forcerecon38's Avatar
forcerecon38
Default ???? on my 81 ???
my rt rear spring is starting to arc down ! if i repair it should i go with coilovers wheh i replace the shocks or a kyb or a monroe sensatrac ?
im looking for the smoothest ride with some better handleing than stock without breaking the bank and yes i know theres only so much i can do !! this is my hwy cruser not a strip car! pls advise you vettesters thanks !!!
Old Jun 8, 2011 | 02:00 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Steel spring or fiberglass? The fiberglass springs do not wear out, although it probably wouldn't hurt to replace the spring cushions.
KYBs would be fine with the fiberglass spring.
