Seat help !!!
Old Jun 11, 2011 | 11:12 PM
u2bdet's Avatar
u2bdet
Default Seat help !!!
Just surrendered to my seats....trying to mount the new cushions in the shell (81) for over an hour, not even close ...anyone have THE SECRET to this ??? There has to be a technique ...
Neal
Old Jun 11, 2011 | 11:22 PM
hammadown's Avatar
hammadown
yes ...mounting them can be a pain the easiest way is with a 10'' or so long screw driver with a notch cut in it. it also helps to tape up the sides of the shells so you dont scratch the paint when using the screw driver. it takes patiance and helps to have an extra pair of hands to hold the cushion to pull/push on it at the same time
Hammadown
Old Jun 12, 2011 | 12:55 AM
wydglydrydr's Avatar
wydglydrydr
Yup, long tool of some sort, When we did the new seat covers in my GFs 82, it was a pain, but we used a long screwdriver and a lot of patience to pop the springs/clips/enemy (call them what you will) into place.
Old Jun 12, 2011 | 12:59 AM
u2bdet's Avatar
u2bdet
Default Thanks
Thanks guys ...going to ruin another screwdriver tom. ..BTW one of the vendors , Wilcox ,I think says that some foam might have to be cut away for installation ...did you have to trim the foam ??
Old Jun 12, 2011 | 01:05 AM
wydglydrydr
Our original foam was is good shape. We put Al Knoch covers over it and all is well.
Old Jun 12, 2011 | 09:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bottoms are slip fit and catch the wire clips rather easily. Backs are more of a PITA. A notch cut in a big screw driver helps considerably. My technique is to seat the wires in the clips on the side farthest from me, then use the screw driver to fit the wires into the clips on the side closest to me.
It's a little spooky using sharp pointy things around upholstery, so I take it slow.
The AIM has a diagram which helps to give an idea of how the installation is supposed to go.
Old Jun 12, 2011 | 04:41 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You shouldn't need to cut the foam to install the covers to the frame. I don't know if this picture will help you but they really are snug when installed new.
Old Jun 12, 2011 | 06:09 PM
THefley's Avatar
THefley
Thanks for posting this, this is one of my next projects is to replace seat pan on drivers side
Old Jun 12, 2011 | 10:21 PM
0Willcox Corvette
Former Vendor
No problem.. part if the install issue is knowing which way the clips face.. and hook.. It's a bear getting new covers to hook. On my old 79 I never hooked the bottoms.. I would alternate them from driver to passenger side to keep the wear even..
To Seat help !!!
