Weird sound
Old Jun 12, 2011 | 10:50 AM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Default Weird sound
78, did a lot of work on it over the winter and into our miserable spring. Eliminated many noises; I've had this particulate squeak for years and I need to figure it out. Listed are the symptoms:
  1. When in drive, foot on the brake, I get a squeak, which matches the shimmy, movement of the engine. Not sure how to describe it other than shimmy, movement.
  2. Sitting in the garage, in park, not running, I can duplicate the squeak by pushing back and fourth on the engine from the passenger side. I can duplicate it from the driver’s side, but it is much more difficult to do.
  3. In park, running, no squeak.
  4. The sound appears to be coming from the rear of the engine compartment, more on the passenger’s side.
  5. Thought it might be the rear motor mount, but feel this is not the case as the mount is so far back and the sound is so pronounce in the engine compartment I don’t see how it could come from there.
Any suggestions, ideas of how to identify the sound will be greatly appreciated.
Thanks Bill
Old Jun 12, 2011 | 11:56 AM
kh400's Avatar
kh400
Thanks Bill
I would buy an electronic chassis ears kit. @$120? Consists of six clips you can attach to various spots that you suspect which go to an amplifier with a six channel selector switch and ear phones. You can switch to listen to various sensors while driving and isolate which sensor the noise is coming from. Works well with some practice. Good luck!!!!!
Old Jun 12, 2011 | 12:45 PM
bluthundr's Avatar
bluthundr
I would start by just laying under the car on a piece of cardboard and having someone rock the engine for you. It may be a lot easier to tell where exactly it is coming from with the engine about 6 inches away from your face.
Old Jun 13, 2011 | 01:21 PM
C3Dani's Avatar
C3Dani
Old Jun 13, 2011 | 02:43 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Originally Posted by c3dani
classic!!!
Old Jun 13, 2011 | 02:54 PM
Dodosmike's Avatar
Dodosmike
Install a louder muffler or open the window or remove the t-top.
no more squeak.
good luck.
Old Jun 13, 2011 | 02:55 PM
C3Dani's Avatar
C3Dani
Originally Posted by 1969RAY
classic!!!
It was either that, or a picture from National Lampoons Christmas Vacation where Aunt Bethany hears the squirrel in Clark's replacement tree.
"It's a funny, squeaking sound!"
Sorry to the OP that I can't offer anything other than humor to your frustrating problem!
Old Jun 13, 2011 | 03:44 PM
garage-ghost's Avatar
garage-ghost
I would check your front passenger side wheel bearing. Just my guess. Good luck finding it.
Old Jun 14, 2011 | 01:29 PM
1969RAY's Avatar
1969RAY
How about a warped rotor that shakes when the brakes are applied.
That shakes the car and makes whatever is loose squeak.
Too obvious?
Old Jun 14, 2011 | 04:23 PM
79L48's Avatar
79L48
Motor mount?
Old Jun 14, 2011 | 06:45 PM
Spocc's Avatar
Spocc
check exhaust - if its close to touching when idling , it may be touching when motoring...
Pete.
To Weird sound
