Spare tire lock
Old Jun 17, 2011 | 03:51 PM
Belgian1979vette's Avatar
Belgian1979vette
Default Spare tire lock
In between doing things to my vette i was taking a look at the spare tire lock. Apparently i seem to be able to push the carrier aside and take it down, without taking the lock off. Is this normal ?
Old Jun 17, 2011 | 05:17 PM
MelWff's Avatar
MelWff
no, are you sure the bolt is completely tightened
Old Jun 17, 2011 | 07:42 PM
Alan 71's Avatar
Alan 71
Hi B79,
When the lock is installed on the bolt properly, the slide pin in the lock holds the the carrier strap tight against the bolt's collar so the bolt can't be slid out of the strap.
Regards,
Alan
Old Jun 18, 2011 | 09:16 AM
Belgian1979vette
Originally Posted by Alan 71
Hi B79,
Regards,
Alan
Well, I tried to mount the carrier as tight as possible to the collar (above the bolt head), but i don't seem to be able to get the lock on.
Is this normal ?
Old Jun 18, 2011 | 09:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The lock mounts over the bolt head. Your owner's manual should show it. It keeps the carrier bolt from being turned when it's in place.
Old Jun 18, 2011 | 01:11 PM
Belgian1979vette
Thanks Mike. That much i figured out, but the carrier bracket doesn't seem to fit in between.
Old Jun 19, 2011 | 10:36 AM
Easy Mike's Avatar
Easy Mike
What size tire and wheel do you have for the spare? Space Saver was stock.
Old Jun 19, 2011 | 11:03 AM
Belgian1979vette
Same height as an original only the rim is thinner.
To Spare tire lock
