Lets Blow Up an Ammeter !
Old Jun 17, 2011 | 11:14 PM
...Roger...'s Avatar
...Roger...
Default Lets Blow Up an Ammeter !
I'm going to try and light this headlight through this ammeter.
What do you guys think,will the ammeter blow ,should I hide ?
Old Jun 18, 2011 | 12:07 AM
Peterbuilt's Avatar
Peterbuilt
Default I'll take a guess!
The meter will deflect towards minus.
Old Jun 18, 2011 | 12:24 AM
bobbarry's Avatar
bobbarry
Jeeps in the 70's ran the ENTIRE charge circuit through their ammeters (no shunt). Yes, they melted, when the battery was low and you had the high-beams on. One headlight through an ammeter should be no danger of fire.
Old Jun 18, 2011 | 12:27 AM
Clubby99's Avatar
Clubby99
Why?
Old Jun 18, 2011 | 12:38 AM
mds3013's Avatar
mds3013
I am thinking the wire will melt before the meter? mike...
Old Jun 18, 2011 | 08:04 AM
...Roger...
Originally Posted by Clubby99
Why?
Why ? Because there are questions as to how sensitive the ammeter is.
The ammeter circuit is wired with a 20 gauge fusible link on both ends.
Are these links in the circuit to protect the "meter" or are they there to protect the car because the meter itself will carry a load large enough to overheat and catch fire ? In other words it will not self sacrifice and open the circuit before it creates a fire ???
http://forums.corvetteforum.com/c3-g...post1577909099
http://forums.corvetteforum.com/c3-t...st-in-car.html
As soon as I eat breakfast I'm going to apply the juice and I believe ( due to past experiences) we'll see this little meter is much tougher than most think.
Old Jun 18, 2011 | 08:32 AM
noonie's Avatar
noonie
Are ther fusible link in your setup as in the car?
Are you using an accurate ammeter as well to check the amp draw for your test?
Old Jun 18, 2011 | 09:26 AM
jnb5101's Avatar
jnb5101
the coil inside that meter is very fine wire, 20 or 22 gauge. it will melt within a few seconds and ruin a $50 meter. got to radio shack or harbor freight and buy a $10 vom(volt-ohm meter). that bulb should draw about 5 amps.
by the way, the corvette gauge is only calibrated to read accurately(by 1960s standards) in the car's circuitry. a stand-alone amp meter is calibrated by way of coil-magnet strength and spring tension.
if you must persist, start with a 1 1/2 volt battery, then a 6 volt, just to see what happens.
Old Jun 18, 2011 | 09:35 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Old Jun 18, 2011 | 09:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ...Roger...
...Because there are questions as to how sensitive the ammeter is....
Has someone hurt it's feelings? Man up and apologize.
Old Jun 18, 2011 | 09:38 AM
...Roger...
Well its been running now for about 15 min. with a full 12 volts,the ammeter is cool as a cucumber.
Old Jun 18, 2011 | 10:10 AM
...Roger...
OK 45 min is long enough for the light,lets run a fan for a little while. (the fan is running but the camera stopped the motion)
Old Jun 18, 2011 | 10:14 AM
...Roger...
Has nothing to do with feelings,its all about accuracy,is that a bad thing ?
Old Jun 18, 2011 | 11:25 AM
Easy Mike's Avatar
Easy Mike
Not at all.
Old Jun 18, 2011 | 11:52 AM
...Roger...
OK an hour and half is enough for the fan. Torture Time
Old Jun 18, 2011 | 12:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Roger... I think you're losing it.
Old Jun 18, 2011 | 12:08 PM
...Roger...
Oh yeah ? How about this ?
To Lets Blow Up an Ammeter !
Old Jun 18, 2011 | 12:14 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
So Roger, what other ways do you spend your Saturday mornings? You may be giving bubba some ideas for some high speed reverse lights.
Are you going to take it to failure with more components?
Old Jun 18, 2011 | 12:25 PM
...Roger...
Actually I'm packing up a ton of old and new parts to go to Bloomington to sell.
(was sending them to Carlisle because I didn't think I would have them ready in time for Bloomington)
Blowing up the gauge was my plan,but now I'm rethinking whether or not that is possible. I'm beginning to think this thing is like a bulb,you can't run anymore through it than it is willing to accept.
Just like putting a 12v test light between the neg battery terminal and the neg cable,you can turn on whatever you want and the test light bulb will not blow,even trying to engage the starter won't blow the test light.
I'm just a dumb ole mechanic trying to understand some of this stuff.
Where are our Electrical Engineers ?
Old Jun 18, 2011 | 12:27 PM
0Willcox Corvette
Former Vendor
Hook the horn up Roger... go for it.. See which last longer.. your mind or the gauge...
