Differential crossmember bushing
Old Jun 18, 2011 | 12:55 PM
Belgian1979vette's Avatar
Belgian1979vette
Default Differential crossmember bushing
I'm putting in a new gear in my diff, so i had to take it out. At the same time i took the diff crossmember out to check it. I have always had my doubts about the fact that the bushing was loose in the bore. Here is a link to the vid.
http://s204.photobucket.com/albums/b...t=MVI_2130.mp4
These are new ones (car has not been driven yet) and came from Corvette America.
Who sells good ones at a reasonable price. Are those from Zip any good ?
Old Jun 19, 2011 | 04:25 AM
Belgian1979vette
Nobody ever had this happening ?
Just need good advice where to get a good quality and size bushing.
Old Jun 19, 2011 | 11:04 AM
Belgian1979vette
Okay, guess i'm the only one ever having to change these. Boy i hate it when i get ripped over ****** parts.
Old Jun 19, 2011 | 11:20 AM
bobbarry's Avatar
bobbarry
Well, mine are fine, so I can't speak to the quality of replacement parts, but you might want to allow at least 24-hours before taking offense that people aren't replying with pertinent answers.
Old Jun 19, 2011 | 11:39 AM
rugerm44's Avatar
rugerm44
I just had mine out.Im pretty picky but changed everything but that.They still look great and fit snug.I feel your pain.I bought a set of adjustable strut rods.One of stripped a thread after being screwed half way in freely.I put a set of stock ones back on it.Not all aftermarket sucks but its becoming a crap shoot.
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Did you bend the retaining tangs over on the other side?
Old Jun 19, 2011 | 11:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Who installed the bushings?
Old Jun 19, 2011 | 02:58 PM
Belgian1979vette
Yes the tabs are bended over and right now, they are the only thing keeping it in place.
I installed it. They fell in place, didn't have to hammer or press them in. I was thinking that when torqued onto the frame, they would somehow expand and would be ok. I should have known better. Anyway, i wouldn't have been able to send them back overseas...
Old Jun 19, 2011 | 02:59 PM
Belgian1979vette
Where did yours come from ?
Old Jun 19, 2011 | 04:22 PM
claysmoker's Avatar
claysmoker
If they just rotate and aren't sloppy in the crossmember, you might consider pulling them out and cleaning up the bushing and the cavity, then installing them with a good coating of silicone rubber adhesive. I know it's a bit of Bubba, but since you are probably never going to replace them again and you are in Europe it might be an OK alternative.
The last ones I bought had to be pressed in. They came from Restoration Auto Parts in Texas. E-mail address is: restorparts@novox.net. The ones prior to that came from Corvette Central. Those had to be pressed in too. My guess is your crossmember is worn. How that's possible I wouldn't guess.
Good Luck!
Old Jun 19, 2011 | 05:47 PM
Belgian1979vette
Good Luck!
Thanks for the links.
I had to press out my originals, so my guess is the cavity is not worn. BTW, i had it powdercoated so even with the coating it still is loose (turning and being sloppy)
Anyway, i'm planning on getting new ones in.
Old Jun 19, 2011 | 06:56 PM
stpman's Avatar
stpman
They must be small, I had to put mine in the freezer for a while before trying to install them in my 73
Old Jun 19, 2011 | 07:13 PM
bobbarry's Avatar
bobbarry
Mine are the original factory-installed units, so that wouldn't be of any help to you.
Old Jun 19, 2011 | 07:48 PM
claysmoker's Avatar
claysmoker
If you want some help getting them, send me a PM. I send things to Europe all the time so I know the customs problems and how to ship so you don't get stuck with duty. Happy to help if you need it.
Dave
Old Jun 20, 2011 | 03:07 PM
Belgian1979vette
Dave
Thanks Dave, i gotta find a correct part right now :
- Doc rebuild doesn't seem to stock these anymore due to obamanomics
- Paragon gave me a dimension which is almost 1 inch to large
- rest of them still have to send me dimensions
Old Jun 20, 2011 | 03:12 PM
claysmoker's Avatar
claysmoker
Hope you get it sorted out OK. If I can help, just let me know.
Dave
Old Jun 21, 2011 | 05:17 PM
Belgian1979vette
So far :
- Zip's bushings are undersize : same as the ones i have in there now
- Paragon seems to have the correct size.
Still awaiting the rest, to see who has the best price for the right item.
To Differential crossmember bushing
Old Jun 22, 2011 | 01:03 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
This is the first complaint that I have heard of on one, but I am looking into it the situation now.
Thank You
Justin
Old Jun 24, 2011 | 01:54 AM
Belgian1979vette
Thank You
Justin
I got the message that you guys are looking into it. It's great to hear that you are going to check it out.
BTW : they bushings in there right now, are not from Zip. However from measuring them, they seem the be the same size. Size in the bore is 3.94"
Old Jun 24, 2011 | 08:41 AM
...Roger...'s Avatar
...Roger...
I haven't read every post in the thread but are you sure the crossmember ID is not too large ?
