Bubba was smart, he knew copper was a good conductor.
I bought a beat-up PU truck years ago that had a .22 shell/bullet in place of the fuse. That fits bubba's personality, I think. I've seen several .22 shells (w/o the bullet) used as fuses over the years. Never seen the tin foil trick, though.
As ol' POP used ta say...." shove in a 4 inch nail and watch for the smoke and you've found your short ".
Poor ol'POP, died in an unexplained car fire.......ONLY JOKING !!!
Yes, fits perfectly! There is a Darwin Award on this subject (with the bullet though ).
Looks like looking at the fuse box clips for each fuse that the whole box has seen some serious moisture with that much rust on it or is that what happens when sitting under a shed awning outside in Florida with the windows and top down for years? Lots of corrosion on the clips. Besides, it looks like the fuse in there is intact so why do it to begin with?
