window regulator spring tension loading
Old Jun 20, 2011 | 05:45 PM
StingrayLust's Avatar
StingrayLust
Default window regulator spring tension loading
I'm putting back together my window regulator and other parts and wasn't 100% at which point I'm to start loading my spring. I'm pretty sure that the left half of this picture is the correct point at which to start loading the spring:
If I try the right half to load the spring tension, there's no way it offers enough spring back to really push up anything.
I'll temporarily put a bolt through that small middle hole while I attach the motor.
