weather-stripping
Old Jun 20, 2011 | 10:22 PM
pleasants9's Avatar
pleasants9
Default weather-stripping
I am repainting my 82 vette and I want to redo the weather stripping. Is there anything I should be looking for? I think I was told Vinyl weatherstripping is best? I want to replace all of it basically except the rear window, I am going to repaint the trip but im not interesting in taking out the window.
Old Jun 21, 2011 | 06:41 AM
dgood's Avatar
dgood
I just replaced the door weather stripping on my 79 after I got it painted. I removed it before paint (pain in the back side). Installation was very easy. I got mine from Willcox. It was hard to close the doors for a few days but I left the doors closed as much as possible and it is very good now.
Used weather stripping adhesive, put it on the door and on the gasket, let it sit for a couple of minutes and then put the gasket on the door. The adhesive is black and really messy. Wear gloves, the stuff is still on my hands.
Old Jun 21, 2011 | 11:43 AM
7T1vette's Avatar
7T1vette
Mask the area outside where sealant is supposed to go to eliminate smearing that stuff on your new paint. Then, when done, you can just pull the tape and be done with it. Also, 'dry-fit' each piece of weatherstrip and place tape or chalk marks on them to identify centers of turns, etc. (registration marks) so that you will know where to stick it down. That stuff will stretch easily and you can get it out of position and 'off track' if not careful. Mark first, so that you don't have to screw around with it after the fact.
Old Jun 21, 2011 | 11:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Make sure your new weatherstrippng is latex. The factory used latex; it seals wind and rain better than the harder stuff.
3M weatherstrip cement and weatherstrip cement remover are good stuff.
Old Jun 21, 2011 | 01:04 PM
golfradict's Avatar
golfradict
Here's a couple of pics of when the doors on my 81 was done. We used tape to help hold it in place.
Old Jun 21, 2011 | 02:15 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We have the CRC USA made weatherstrips listed in the forum sale section. This are the highest quality weatherstrips being produced!
You can also use the current 10 percent off coupon in our sale thread on this.
http://willcoxcorvette.com/product_i...ducts_id=25490
Willcox
Old Jun 21, 2011 | 09:37 PM
pleasants9's Avatar
pleasants9
^thats what I was looking at wilcox, but it looks like it is rubber weatherstripping not latex? well i guess latex is rubber.
Old Jun 22, 2011 | 08:48 PM
pleasants9's Avatar
pleasants9
thanks for all the input guys
Old Jun 22, 2011 | 08:59 PM
doctorgene's Avatar
doctorgene
7T1Vette Good tip, marking & taping. Thanks Gene
Old Jun 23, 2011 | 07:40 AM
Paul L's Avatar
Paul L
Originally Posted by pleasants9
anyone know if the this wilcox weatherstripping is vinyl?
It is rubber, soft and pliable. just what you want. I have never seen vinyl weatherstripping.
Old Jun 23, 2011 | 09:39 PM
0Willcox Corvette
Former Vendor
original weatherstrips have a skin on them where applicable like the originals. The original skin was not vinyl.
Old Jun 23, 2011 | 10:21 PM
THefley's Avatar
THefley
Nice thx
Old Jun 23, 2011 | 11:36 PM
orourke's Avatar
orourke
Be sure to wipe the new weather stripping off with lacquer thinner to remove the release agent. Pour the glue onto a paper plate. Use an acid brush to apply a thin coat of glue onto both the door and weather stripping. Wait a minute or two then press together. Do a section at a time. It will be on there for good.
Marty.
Old Jun 27, 2011 | 07:35 PM
pleasants9's Avatar
pleasants9
I think I meant latex, thanks for all the help still!
Old Jul 19, 2011 | 11:19 AM
mrandig's Avatar
mrandig
Default blow out tabs
Hi guys:
I had posted this in another thread, but am also trying here also, since this one is more current.
Anybody have any tricks to repair/replace the upper blowout tabs?
I've got them off, just need to recoat and figure out how to reinstall; off-the-shelf rivets just seem too big, but I want to check before I try and tear anything up.
Mark
To weather-stripping
