Hood too high in front
Old Jun 28, 2011 | 10:56 AM
Dantana's Avatar
Dantana
Default Hood too high in front
Hi All,
I've had this problem for a long time now (car came to me this way) and I have prioritized other things until now. In the front it sits about 1/2" too high but is correctly aligned on the driver's side and sits about 1/4" high on the passenger side in the front. I've done some searching and it seems many have broken the bond between the inner fenders and the hood surround to bring the surround up and then rebonded it. Is this my best option? Will that bring the nose up or is there an adjustment somewhere? My AIM is a little criptic...
I do not have any shims under the hinges.
Thanks,
Dan
This pic is from Bloomington Gold last weekend:
Old Jun 28, 2011 | 11:17 AM
mysixtynine's Avatar
mysixtynine
Most likely what you are dealing with is an aftermarket hood that isn't quite right.
My hood is also high in the front if you line up the sides of the hood where it meets the "hips" of the fenders. I have seen allot of aftermarket L88 style hoods where the tip of the hood is simply too high like the hood wasn't sloped enough in the mold.
If you lower your hood to where the tip is inline with the surround you will most likely find that now the sides of the hood where it meets the fenders will be too low.
If you have no shims to remove then you are as low as you can go. I had the same issue and instead opted to cut my hinges and reattach them with 1/8" of metal removed from the sides so that I could now use shims.
I was able to then get a happier medium when the tip of the hood is slightly high and the sides are slightly low. Its not perfect but it looks ok and unless you scrutinize or know to look for it, it doesn't just jump out.
Old Jun 28, 2011 | 11:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Dantana
...many have broken the bond between the inner fenders and the hood surround to bring the surround up and then rebonded it. Is this my best option?...
Maybe.
See if you can raise the front of the hood surround panel with the bar and skirt reinforcements underneath. Easy does it. Don't try to force anything.
Nose bar runs from the bottom of the radiator support to the top of the nose.
Old Jun 28, 2011 | 04:16 PM
Roco71's Avatar
Roco71
Mike, Can you raise the nose on the car by shimming the bottom bolts of the radiator support and “V” crossmember? I did something to that effect on mine a couple of years ago to raise my surround to get it even with the hood. I can’t remember if that was it or not.
Scott
Old Jun 29, 2011 | 12:32 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Roco71
...Can you raise the nose on the car by shimming the bottom bolts of the radiator support and “V” crossmember?...Scott
Yes. A little. Most of the AIMs show the shims with a note "As Needed." Someone can correct me, but I think the V member is chrome bumper cars only. Don't the rubber bumper cars use a different arrangement?
Old Jun 29, 2011 | 01:41 PM
mysixtynine
Guys, I am trying to get my head around the idea of how raising the radiator support by putting shims under it is going to raise the hood surround independent of the hood when the inner fender wells are bonded to the fenders and the hood is mounted to the top of the inner fender wells and the radiator support is sandwiched and bolted to the inner fender wells?
Just seems like you are going to push the entire nose up in the air compared to the rest of the body?
Old Jun 29, 2011 | 03:43 PM
Roco71's Avatar
Roco71
A few years ago when I got my car ( a failed restoration in boxes) the nose was totally loose and ¼ to 3/8th of an inch lower than the hood. Most of the bolts were missing or only hand tightened. I did a search here and found this thread and followed the procedure in the fifth post. I replaced the missing bolts and tightened them up and it worked.
http://forums.corvetteforum.com/c3-t...mess-with.html
Old Jun 29, 2011 | 06:00 PM
Dantana's Avatar
Dantana
Interesting procedure in that other post. When I got the car I didn't have 4 of the 6 bolts in the core support. I just put them in there, and had to fight them in if I recall. I don't remember the nose moving up or down after I installed them, seems it stayed in the same place.
So I will look at the bar and skirt reinforcements and the core support and see if I can budge it.
Am I the only one worried that if I move the core support (or combination of parts) up 1/2" I will crack the glass?
Old Jun 30, 2011 | 07:25 AM
Roco71's Avatar
Roco71
My situation was a little different the only thing bolted on my car was the body mounts. When I went to push my car from the front (to my surprise) the nose lifted over an inch and without any damage. It was in primer so I am not sure what would have happen if it had been in paint.
Old Jun 30, 2011 | 08:22 AM
70BBvert's Avatar
70BBvert
Maybe.
If the skirts are bonded well to the fenders then this is the only way to raise the surround in that area. But you'll only get a small amount of movement. Use shims and/or washers between the brace & header bar. Those triangular shaped pieces are for reinforcement, not adjustment purposes.
Raising the front frame extensions/core support moves everything at the same time, hood & the surround. This can fix a nose that sagged or door gaps, but the only way to adjust the surround relative to the hood is to break the bond at the skirts, adjust the position and re bond everything.
Jim
Old Jun 30, 2011 | 04:36 PM
Dantana's Avatar
Dantana
Thanks Jim.
Is this doable in the garage? It sounds like more of a body shop thing because they would have the equipment to raise the surround and hold it. I could do this with shims without cracking the paint and the fiberglass?
Old Jun 30, 2011 | 07:15 PM
Mark G's Avatar
Mark G
I believe it is also an aftermarket hood from a poorly constructed mold. The rad. support doesn't have anything to do with the hood mount. Like the others pointed out, it's the fender skirts. If it were me I would:
1) Look for a factory hood, which you probably don't want to do cause yours is all nicely painted up.
2) Keep your hood and remove your hinges and cut 1/2" of material from them and re-weld. Or, get a set of used hinges from someone on the forum and cut/weld them down till the front of the hood matches to your satisfaction. You could send them off and get re-plated and nobody would know but you. Then, someday you could always put on a different hood and your original hinges and it will still fit.
Cutting the hinges and re-welding shouldn't take more than 1/2 day. To me it's the path of least resistance from what I can tell.
Mark G
Old Jul 2, 2011 | 09:06 AM
70BBvert's Avatar
70BBvert
Thanks Jim.
I suppose its doable at home, but if everything else lines up right, I'd be inclined to do as Mark suggests & modify the hinges. Cut them shorter than you need & shim the hinges to correct the lines.
A pair of hinges is a lot less expensive than body work
Jim
Old Jul 2, 2011 | 07:58 PM
ButchN's Avatar
ButchN
I just went through this on my car.
I ended up adding a shim to each side on the front (nose), which actually made that line up mint, but taking out the shims at the latches resulted in my hood not wanting to latch when shut.
So I added shims until it latched solidly which gives me about an 1/8" rise which I'm fine with because, I don't see it while driving, the hood is up at shows anyway, & we all know C3 lines are never perfect!
To Hood too high in front
