grounding cable
Old Jun 30, 2011 | 01:16 AM
trostvette's Avatar
trostvette
Default grounding cable
I have a 76 stingray L82 with a 350. anyway the battery is behind the seat and goes down to the frame I need to replace and it is alot heavier than the ones I find at auto stores I beleive its a -0 do I need one that big? thanks
Old Jun 30, 2011 | 05:29 AM
dgood's Avatar
dgood
On the Willcox site, they list the set of cables for your 76 for $50 and they don't say what gauge. The 80-82 uses 0 gauge. Zip Corvette sells the negative cable for 25 bucks and it is listed for 76-82 but does not give the gauge size. Not sure.
Old Jun 30, 2011 | 05:35 AM
hunt4cleanair's Avatar
hunt4cleanair
I just paid $29 for the ground cable from starter support bracket to chassis...so they are pricey and specialized. Mine was frayed and the rubber had baked from what appeared to be excessive heat. It was only a foot long and I got from The Last Detail.
Old Jun 30, 2011 | 09:39 AM
7T1vette's Avatar
7T1vette
The cable on the '71 is 4 awg. Later years may have gone to larger size; check the GM wiring diagram to determine size. Go to Lowe's and buy the length of 4 awg (or whatever is required for your car) and an appropriate lug to solder on the end. Take them home and solder with a propane torch. If you really want to pay someone else to do that, just buy one from one of the CF vendors.
Old Jun 30, 2011 | 10:05 AM
garage-ghost's Avatar
garage-ghost
This is a case, where big is definitely better.
Old Jun 30, 2011 | 10:46 AM
Ironcross's Avatar
Ironcross
any quality auto parts store will probably have them in stock as a copper cable in either 4 or 2 gauge wire with the appropriate ends....no need to go to the net or make one.......Belding, Niehoff, Standard, are all quality ignition parts....bolt right in....
Old Jun 30, 2011 | 11:33 AM
joewill's Avatar
joewill
i got one, about 8 bucks at target...
Old Jun 30, 2011 | 11:50 AM
...Roger...'s Avatar
...Roger...
Old Jun 30, 2011 | 01:12 PM
SIXFOOTER's Avatar
SIXFOOTER
Originally Posted by ...Roger...
Old Jun 30, 2011 | 01:30 PM
7T1vette's Avatar
7T1vette
AutoZone and Target probably have 'one' for $8...but it's likely made of aluminum wire and won't handle nearly as much current or last as long. You get what you pay for....
Old Jun 30, 2011 | 02:04 PM
joewill's Avatar
joewill
it cranks over my big block real well, even when hot...
Old Jun 30, 2011 | 03:38 PM
7T1vette's Avatar
7T1vette
And, I sincerely hope that it continues to do so...
Old Jul 1, 2011 | 12:09 PM
kdf1986's Avatar
kdf1986
I also found that my local parts store does not carry the same gauge as what I have on my 73. I did not think about going to Home Depot to look for that cable gauge. Thats a good idea I will have to look into.
kdf
To grounding cable
