My buddy is tearing into his cali, 82 cross-fire. We are going to carb. it. Can anybody tell me why the rear water jackets were plugged? Also the cross-fire had a return fuel line, does this line go straight to the tank, or to the fuel pump in the tank? When we put the carb, on can we just plug the return line? Thanks.....
There's no cross coolant passage in the back of the intake,the return drops in the top. You can plug the return but using it as a return is a better way to go.
So when we replace the old cross-fire intake with a RPM intake, we can take those out.
If the RPM intake has a coolant passage at that spot, yes.
As to the fuel system, if you are going to use the existing fuel pump you will need to put a pressure regulater in the line. That pump likely puts out about 40 psi or more and a carb only wants around 5. Ideally you want the style that is mostly used in the oe injection system, one that dumps flow back to the tank to reduce pressure. An in tank pump likes to flow fuel to keep cool. I would suspect that it would cut the life expectancy quite a bit if it was only allowed to flow what the needle and seat will allow.
Chevy heads are open, some intakes are closed in the back.
The fuel pressure is only around 15psi, but it's still way too much for a carb.
It's always better to use a return and one of the reasons is a more consistant flow and pressure.
Use a good quality "bypass regulator" and try for as little pressure as possible and increase pressure until it won't starve at flat out rpm for whatever time period you can get away with.
I've run qjets with as little as 4psi.
Thanks noonie!! I was told I needed a regulator. But I really didn't believe the pump was putting out that much psi on this set up. Serves me right for not listening. But on the other hand I learned somthing new again. LOL..
Your going to have some electrical hurdles to overcome with the electric pump,it might be easier to just add a mechanical pump.
Why? Shouldn't the pump be on when the key is in the on position. Worst case I should be able to connect the wires leading from the pump to a circut that is on when the key is on. Anyways we are getting a new electrical clip that will help with the auto tranny. It's made for this conversion.
If I remember right the fuel pump is tied to the computer plus an oil pressure sensor.
Not sure exactly what your eliminating. No doubt with some wiring you can make it work but as you said you have to buy a fuel reg so I just wondered if going to a mech pump might be a simpler way to go.
I believe the mech.pump is the way to go too. But my buddy does'nt want a mech. We'll see how things turn out.
