'71 Motor ID
Old Jul 6, 2011 | 10:15 AM
EngineerJay's Avatar
EngineerJay
Default '71 Motor ID
I have a question with where on the motor the numbers are located on a small block?
I have been trying to find it since I got it a few weeks ago and I am not sure I am looking in the right location. I just want to know what the number is for my own curiosity.
Thanks for your help!
Jay
Old Jul 6, 2011 | 10:44 AM
jackson's Avatar
jackson
fill in your profile an approximate geographic locale
e.g. Where you live may determine which is driver side.
right side (passenger) cylinder bank.
front of block where head mates to block.
in same plane as & in perfect alignment with right deck of block.
a smooth horizontal iron surface with a vin DERIVATIVE stamped into pad
Old Jul 6, 2011 | 04:47 PM
garage-ghost's Avatar
garage-ghost
And if it has paint over it, don't scrape it off with a metal object, use finger nail polish remover or paint stripper.
Good luck.
Old Jul 6, 2011 | 08:28 PM
Alan 71's Avatar
Alan 71
Hi jay,
You may want to check the casting number and date code for the cylinder case too. They're both on the rear flange of the block behind/below the distributor and just in front of the bell housing.
For many people they're a part of the number business too.
Regards,
Alan
Old Jul 7, 2011 | 01:43 PM
EngineerJay
Here is a picture of the front passenger side of the engine block. Where should I look from here?
Old Jul 7, 2011 | 01:50 PM
71 Green 454's Avatar
71 Green 454
Scrape off paint to read the numbers.
Old Jul 7, 2011 | 03:22 PM
Mike Ward's Avatar
Mike Ward
Never scrape , use paint remover of some sort.
Old Jul 7, 2011 | 03:29 PM
71 Green 454
OOPS....my bad. You're right as usual Mike.
Old Jul 7, 2011 | 03:50 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Here ya go:
71 small block shown. Yours will be similar. Larger characters indicate engine ID stamp; smaller characters are the VIN derivitive.
To '71 Motor ID
