73 Stereo Amp (convector) placement???
Old Jul 7, 2011 | 05:03 PM
udornf4's Avatar
udornf4
Default 73 Stereo Amp (convector) placement???
I must be putting the stereo Amp in the wrong place. The heat sink top hits the bird cage and the bottom hits the a/c ducting. I guess is doesn't go where I have pictured. It shows it there in the AIM - but not even close to a fit.
A mono AMP would probably fit there - but not the bigger one with two transistors.
Screw holes (already there) appear to be correct for this amp.
Anyone have a two transistor AMP (convector) installed (pics)?
Old Jul 7, 2011 | 06:09 PM
7T1vette's Avatar
7T1vette
The convector for my '71 is mounted 90* different than yours. The tops of the transistors face the passenger compartment and the mounting flanges screw into that upper metal surround rather than underneath it. I can't say if that is the way it came from the factory...but it doesn't interfere with any other components there.
Old Jul 7, 2011 | 07:49 PM
Duke94's Avatar
Duke94
I think my 71' is just a mono (smaller), but you can see how it's mounted.
Gary
Old Jul 7, 2011 | 09:10 PM
Blue73Shark's Avatar
Blue73Shark
placement in my 73 dash (mono)
Old Jul 7, 2011 | 09:14 PM
Duke94's Avatar
Duke94
[QUOTE=Blue73Shark;1578074845]placement in my 73 dash (mono)
[Looks like the same as my 71'
Old Jul 7, 2011 | 09:45 PM
Tom73's Avatar
Tom73
Your heat sink looks different from any I've seen.
Old Jul 7, 2011 | 10:21 PM
oldsarge's Avatar
oldsarge
Your unit looks the same as my 73 for stereo set up, but I think you have to move it to the left, closer to the center, like in Tom's pic from the AIM.
Old Jul 9, 2011 | 02:44 PM
Tom73's Avatar
Tom73
udornf4,
Here are some pics of the Heat Sink and the Multiplexer from my '73. Very different than those that you show.
HEAT SINK
MULTIPLEX ASSEMBLY
I have no idea what that is you have in yours.
Old Jul 9, 2011 | 04:18 PM
dembo's Avatar
dembo
This is a pic from 15 years ago before the resto, you can still see the placement on the RH side (stereo), but my car is a 74
Nick
Old Jul 10, 2011 | 11:35 AM
oldsarge's Avatar
oldsarge
Originally Posted by Tom73
udornf4,
HEAT SINK
MULTIPLEX ASSEMBLY
Tom, is that not for a mono radio, that you are showing in your pics, the one in udornf4, looks like one for a stereo set up, it appears to look the same as mine. I will post a few pics, later.
Old Jul 10, 2011 | 11:36 AM
udornf4's Avatar
udornf4
Default thanks!
Thanks, Guys. What I think I have is a '74 Stereo - trying to fit it in a '73. It should fit - but doesn't. I had to "bubba" it a bit (cut off a few heat sink fins). Fits now...
Still, I would like to see a close up of a '74 Stereo Amp (on a car with A/C). I just don't see how it would ever get installed there with the ducting, etc..
Thanks, again
Old Jul 10, 2011 | 12:01 PM
oldsarge's Avatar
oldsarge
Here are the pics of the convector for the stereo radio, that is in my 73.
Old Jul 10, 2011 | 12:22 PM
7T1vette's Avatar
7T1vette
If you look at the mounting brackets closely, you will notice that one of them can be removed and replaced in a different orientation. I believe one of those mounting positions is used for non-A/C cars and the other for A/C cars. (I don't know that for a fact, but only one way will work for my '71 A/C car.)
Old Jul 10, 2011 | 04:59 PM
oldsarge's Avatar
oldsarge
Just to add to that, the pics I show have the brackets set for an A/C car.
Old Jul 10, 2011 | 06:46 PM
Tom73's Avatar
Tom73
Interesting, my pics are for a 73 stereo. Came out of my 73 vert when I installed a Kenwood. It ws an early 73, second month of production. Is your a late production maybe?
Old Jul 11, 2011 | 08:45 AM
oldsarge's Avatar
oldsarge
Tom, my build is October 21.
Old Jul 11, 2011 | 08:10 PM
udornf4's Avatar
udornf4
Default still need help...
Guys - thanks for the info of the mono amp (one transistor), but I have the Stereo Amp (TWO transistors) - It is about 4 times bigger than a mono amp.
Sarge - I have the exact same AMP as your pics!
I just can't find the proper place to mount it in my '73 (A/C Car)
Someone surely has a pic of a mounted STEREO Amp in a A/C car
To 73 Stereo Amp (convector) placement???
Old Jul 11, 2011 | 08:55 PM
oldsarge's Avatar
oldsarge
Here is an old pic, before I took it out. It is not a great pic, I had to scan an old photo, sorry.
Old Jul 12, 2011 | 04:27 AM
dembo's Avatar
dembo
Well my picture (not the best) shows you the original location and although the heater box is not in, it's above it anyway
Nick
Old Jul 12, 2011 | 10:18 AM
udornf4's Avatar
udornf4
OK - got it! Looks like the left mount is either the same as the Dash Brace or very close to it!!!
Thanks so much!
