Vacuum Leak....
Old Jul 9, 2011 | 11:35 AM
Richard Cooper's Avatar
Richard Cooper
Default Vacuum Leak....
I put a new crate motor in my 81 a few months ago. I would like to check around the intake manifold for vacuum leaks, can anyone suggest something to spray that will not make a mess of my new motor?
Old Jul 9, 2011 | 12:12 PM
Rick_V's Avatar
Rick_V
I have never tried it but, I have read that spraying water in a mist form works well. if your engine stumbles you have found your leak.
Old Jul 9, 2011 | 12:53 PM
qwank's Avatar
qwank
carb cleaner
Old Jul 9, 2011 | 02:45 PM
Richard Cooper
Thanks guys, Rick, I'll try the water mist first and if it does not work I'll try what Qwank said, carb cleaner. Have a good weekend.
Old Jul 9, 2011 | 03:08 PM
STINGRAY1WORD's Avatar
STINGRAY1WORD
Propane bottle with a fuel hose sliped over the torch end. Just guide the hose where you want and if rpms change you found the leak.
Old Jul 9, 2011 | 07:28 PM
scottyp99's Avatar
scottyp99
Old Jul 9, 2011 | 09:00 PM
7T1vette's Avatar
7T1vette
Carb cleaner is best. It is volatile and will provide more "fuel" to the intake charge if it is actually ingested when you spray it. Spray small puffs of cleaner directly at the gasket area you want to check out. Spray at one area, then wait to hear if the engine revs up a bit (or not). Then move to another area. Spray along both sides of the intake manifold to cylinder head gasket areas and around the base/throttle shafts of the carburetor.
Old Jul 9, 2011 | 10:24 PM
Richard Cooper
Thanks again everyone.
Old Jul 10, 2011 | 12:29 AM
Vette5.5's Avatar
Vette5.5
Carb cleaner makes a great paint stripper. Keep this in mind before using it on external parts.
Old Jul 10, 2011 | 03:11 AM
7T1vette's Avatar
7T1vette
That's why you shoot little puffs of cleaner right at the gasket when you test. Never get the surface "wet".
Old Jul 10, 2011 | 06:44 AM
dgr72vette's Avatar
dgr72vette
smoke machine
To Vacuum Leak....
