brake problem
Old Jul 16, 2011 | 06:00 PM
hmosefski's Avatar
hmosefski
3rd Gear
Default brake problem
just replaced a brake line in a 1977 with disc brakes . Bleed all four wheels in recomended sequence lr,rr,lf rf,due to the car sittig with no brake fluid in the system,because it had a leak thru the previous months while it sat idol.My question is, why can't I build any pressure to get a good pedal.I bleed each wheel a number of times ,I don't see any leaks, and the pedal still goes to the floor. What am I missing?
Old Jul 16, 2011 | 08:12 PM
68sbcoupe's Avatar
68sbcoupe
probably air in the master. try bench bleeding it, then gravity bleed the calipers.
Old Jul 16, 2011 | 09:34 PM
dgood's Avatar
dgood
Concur with 68. Tried the pressure bleeding route and could never get it. Bench bled the master cylinder and then gravity bled the calipers over a long day.
Old Jul 16, 2011 | 10:04 PM
Phlash's Avatar
Phlash
Though you probably did this, I will ask anyway. Did you bleed both sides of the calipers on each rear brake? Did you lightly rap the caliper bodies with a small hammer to help move any trapped bubbles inside the calipers while you are bleeding the calpers?
Old Jul 17, 2011 | 06:18 AM
hmosefski's Avatar
hmosefski
3rd Gear
I did bleed both sides ,I did not lightly tap caliper. But I'll try.thanx
Old Jul 17, 2011 | 06:21 AM
hmosefski's Avatar
hmosefski
3rd Gear
how do you bench bleed?First Vette,never heard of it
Old Jul 17, 2011 | 08:40 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by hmosefski
...Bleed all four wheels in recomended sequence lr,rr,lf rf,...
Bleeding order is wrong.
Left rear inner
Left rear outer
Right rear inner
Right rear outer
Right front
Left front.
To brake problem
