Heater Hose
Old Aug 4, 2011 | 11:26 AM
65-396's Avatar
65-396
Default Heater Hose
I have a '72 LT1 coupe w/air conditioning. This is an original 19,000 mile survivor car. A few months ago the heater core decided to fail. Unfortunately I was several hours away from my house so I decided to have a service station re-route the heater hoses so I could replace the heater core at home. I told the mechanic to just remove the hoses at the heater core nipples and splice them together. When I got home and started the repair, to my horror I found that he didn't remove the hose clamps and slide the hoses off the nipples. He cut the hoses at the 90 deg. bends! I'm devastated. Here's my question. Who makes the correct reproduction hoses for this car? They are ribbed with the 5/8" hose having 1 solid white stripe the length of the hose and the 3/4" hose having 2 solid white stripes the length of the hose. These are the only markings. Thanks
Old Aug 4, 2011 | 01:13 PM
jam23059's Avatar
jam23059
Look in the Zip catalogue. They do have reproduction hoses with the GM markings
Old Aug 4, 2011 | 01:24 PM
Mike Ward's Avatar
Mike Ward
Most likely the hoses would not have come away cleanly from the heater core and if they truly are original, are waaaaaaaaaaaaaaaaaaaay past their intended life span.
Most of the reproduction hoses have some markings on the them, like the GM logo, which were not necessarily on the originals.
Old Aug 4, 2011 | 01:36 PM
Paul L's Avatar
Paul L
They come off with an XActo knife.
Old Aug 4, 2011 | 01:38 PM
Steve~74's Avatar
Steve~74
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Try Dr. Rebuild....link provided.
http://docrebuild.com/dr-r-web/heater-hoses.HTML
Old Aug 4, 2011 | 02:01 PM
Alan 71's Avatar
Alan 71
Hi 65,
I don't think I've seen original heater hoses with a stripe of any color on them.
Also, I believe the original hoses had various numbers of grooves cut in them to indicate the supplier, not raised ribs. If you look VERY carefully at the hose surface you can see the grooves, and not ribs that are raised above the surface of the rest of the hose.
Regards,
Alan
Old Aug 4, 2011 | 02:45 PM
corvetteload's Avatar
corvetteload
Dr Rebuild has them, ZIP sells rip-offs
Old Aug 5, 2011 | 12:19 PM
65-396's Avatar
65-396
Thanks for the responses. This is what I have found. All original heater hose, whether it was a C-2 or C-3 had a set of ribs (or grooves or ridges, how ever you want to call them). Depending on year and engine application they had various markings. No one at this time reproduces the ribbed hoses for an A/C car. Dr.Rebuild sells hoses that are the closest in appearance, but with no ribs, so they are incorrect also. The original hoses are still soft and supple and the stub ends that were left on came right off. (The joys of living in Colorado and being in storage it's whole life). I will keep the old hoses for any reference and documentation if anyone is interested. Hopefully someone will reproduce them someday.
To Heater Hose
