Drivers door lock problem
Old Aug 16, 2011 | 11:09 PM
BARRY L-48's Avatar
BARRY L-48
Default Drivers door lock problem
I have developed a problem with locking my drivers side door.If I open the door I can lock and unlock the door with no problem,but with the door closed,it does not want to lock unless I pull the rod inside the door, I have sprayed lubed the lock mechanism but it did not help,could my door striker be the cause of the problem, I am thinking it could because it locks and unlocks easily with the door open,anyone have any ideas on this?
Old Sep 11, 2011 | 12:30 PM
biscuitville's Avatar
biscuitville
Default me too
Barry,
I am dealing with the same issue on the passenger side. I will post something if I get it solved.
AL
Old Sep 11, 2011 | 12:35 PM
blueray72's Avatar
blueray72
check the rod clearance, grease levels at the door handle.
Old Sep 16, 2011 | 09:09 PM
biscuitville
Default Solved it
Bought a new door latch. Worked like a charm right away. Spent hours removing/cleaning/lubing/replacing the one to no avail. When holding it in my hands it appeared to work fine. It wasn't until I bought a new one that I could tell the old one required more force to open.
While not the most satisfying route, buying a new one was certainly the quickest fix.
BTW - after all of the work, modifications, etc. I have done to my 73, fixing the door latch has been the repair my wife enjoyed the most.
Old Sep 16, 2011 | 09:17 PM
dogboy's Avatar
dogboy
Had the same issue with both doors in the past on the 77. I bought good used mechanisms to solve the problem . I did notice the old one had a broken rivet so it would expand when turning the key and jam up. One other thing. Check that the door alignment hasn't changed.
To Drivers door lock problem
