Vacuum relays - $$$$ vs $
Old Sep 14, 2011 | 05:43 PM
C6DuffMan's Avatar
C6DuffMan
Default Vacuum relays - $$$$ vs $
Are the more expense ones worth it? It seems every vendor sells both. The cheap ones are about 1/3 of the expensive ones.
I need to replace all three in my 71. No, I can't rebuild them. They're too far gone.
Old Sep 14, 2011 | 06:21 PM
joewill's Avatar
joewill
which relays? headlight?, heater control?
Old Sep 14, 2011 | 06:30 PM
C6DuffMan's Avatar
C6DuffMan
Headlight and Wiper Door.
Old Sep 14, 2011 | 10:59 PM
7T1vette's Avatar
7T1vette
Hey. Order the cheapos, but buy two of each piece! That's still less expensive than buying the high-priced "spread". That should keep you up-and-running for at least 10 years.
Old Sep 15, 2011 | 12:41 AM
Dose11's Avatar
Dose11
That makes a little bit of sense
Old Sep 15, 2011 | 10:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You usually get what you pay for.
Old Sep 15, 2011 | 10:44 AM
7T1vette's Avatar
7T1vette
In past times, I would tend to agree with Easy Mike. But, with the '*****-nilly' aftermarket parts business the way it is these days, there is no consistency on the hi-priced parts being significantly better. I believe the "costlier is better" approach does hold true for critical "hard" parts, like steering/suspension items...as long as you purchase a known-good brand. For other parts...not so much.
Old Sep 15, 2011 | 11:29 AM
Easy Mike's Avatar
Easy Mike
...these days, there is no consistency on the hi-priced parts being significantly better.
That's why I put the "usually" in there.
Old Sep 15, 2011 | 02:47 PM
Makonut's Avatar
Makonut
It depends. The 3 smaller relays being offered are delco like the factory original. Do you want the correct appearance part, if not go for the imports.
Old Sep 15, 2011 | 03:12 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
From a sales point I'd have to say no... go with the cheap relay, the higher priced ones are not worth it. There are several manufacturers of this imported valve and the one we carry now has a perfect sales to return ratio. Zero returns year to date and over 150 pcs sold.
We used to get these from a different supplier and boy they were a nightmare.
IMHO,
Willcox
Old Sep 15, 2011 | 03:16 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Got mine at Willcox. Good (actually the best) price and they work great. No complaint here.
Old Sep 16, 2011 | 01:01 PM
C6DuffMan's Avatar
C6DuffMan
IMHO,
Willcox
Good to know! Order placed for three.
Old Sep 17, 2011 | 12:05 AM
0Willcox Corvette
Former Vendor
To Vacuum relays - $$$$ vs $
