What's your vaccum?
Leave all systems connected, T-in the vacuum gauge, and start the car and let idle. Get a couple of 'squeeze clamps' or a small Vise-grip. Put the clamp/VG on the vacuum line just after the gauge connection with the intent of clamping off that line. Read the vacuum gauge. You should get about the same reading as the "baseline" level...about 16" Hg. Now, continue to move the clamp/VG farther downstream, clamping off the hose and taking a reading. When you find that the vacuum drops more than 1-2" Hg, you have just gone beyond the site of a vacuum leak. Check between those two clamping locations for possible leaks; use your fingers/hands/tape/etc in an attempt to seal the leak and make the reading go back to the baseline level.
That's the process. Just keep doing that, finding leaks and fixing them until you find all the big ones. You may have a connection loose or a split in a hose, or a leaking diaphragm on one or more components in the system. If you find that the leaking line goes into the interior of the car, just go under the dash [or wherever] to continue with your search process. You may need an 'assistant' to watch the gauge for you as you test the system.
Good luck!
