A/C problem
Old Aug 20, 2011 | 05:52 PM
jeepman3080's Avatar
jeepman3080
Default A/C problem
My A/C on my 77 vette is only blowing thru the foot vents. It was blowing thru all vents but now all of a sudden just the bottom vent on both sides. Any help.
Old Aug 20, 2011 | 05:58 PM
Ganey's Avatar
Ganey
I wrote this up awhile back for this problem.
On at least later C3 the problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default. Very safe bet the problem is 1 OR 2:
1) The vac. line from engine may be damaged from heat - a small plastic tube that goes in pass. side of dist. below the hood alarm switch into wiper valley. Replacing most of engine side w/ hose will normally fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or disassemble to lube w/ a thin layer of white lithium grease to fix. Try pressing the 2 halves of the switch together to test in A/C or VENT w/ engine running.
3) If you have a heater, the small vac. tube to heater hose valve under hood may be damaged from heat & need replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends
Old Aug 20, 2011 | 11:10 PM
jeepman3080
Thanks, I will dig into it in the morning and see if I can find the problem.
Old Aug 21, 2011 | 01:04 AM
Steve2147's Avatar
Steve2147
The design "problem" is not a problem at all, but rather a safety feature. I'm not sure why his and your c3 go to high heat and floor vent, the design is supposed to be high heat and defrost in the default no vacuum position.
Steve g
Old Aug 21, 2011 | 09:05 AM
Ganey's Avatar
Ganey
That refers to 'Vent should be default" at least in the south.
Old Aug 21, 2011 | 09:59 AM
jeepman3080
Steve g
I have got to have the worst luck. I have a new A/C compressor installed last year. Never used the A/C until I started working on this problem. The A/c felt good on my feet so last night when me and the Wife were going to a car show I turned the A/C on for the first time. About 15 minutes later the compressor quit and the fan belt burned up. Just my luck.
To A/C problem
