c3 convertible conversions
Old Aug 24, 2011 | 02:15 PM
Nasty73's Avatar
Nasty73
3rd Gear
Default c3 convertible conversions
I have read some of the threads on this subject. I am looking to convert my 73 coupe into a convertible. I would love to hear and see the progress of any of the same projects out there.
Old Aug 24, 2011 | 04:25 PM
69VetteFla's Avatar
69VetteFla
Someone recently posted a pic of a t-top/convertible - something I never saw before that you might want to think about if you are going to start chopping. Couldn't find the link to the thread but maybe someone else might be able to help. Was actually pretty cool - had the t-tops but then the entire top including the t's would come off too.
Old Aug 24, 2011 | 06:42 PM
Alan 71's Avatar
Alan 71
Hi n73,
There have been several threads about convertible conversions; perhaps they were finished, but the threads ended before the finished product was shown.
I think that convertible conversions are a lot like conversions to chrome bumpers.... what ever you think of those.
I can understand doing a convertible conversion on a model year when convertibles were no longer available, but not on a 73.
Personally, I'd sell my coupe and buy a convertible.
Regards,
Alan
Old Aug 24, 2011 | 06:54 PM
Clams Canino's Avatar
Clams Canino
Agreed - you could sell the '73 for enough money to buy an '81 and the parts to convert it.
Basically - you need the rear clip off a KIA vert - and then you graft the right parts on. It's been done.
-W
Old Aug 24, 2011 | 07:12 PM
Nasty73's Avatar
Nasty73
3rd Gear
Here's the thing. I picked up this 73 for next to nothing. It is already frankenvette with non numbers matching 454 and a crunched nose. (I already have the front clip) I am already going to be doing serious restoration on the car. I just like the look of a convertible so much better. I am not afraid of the work. I just wanted to see how some of the other projects turned out. Thanks
Old Aug 24, 2011 | 07:18 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I agree with Alan and Clams: less of a hassle to purchase a convertible.
If you actually want to take a look at the chore, my suggestion would be to purchase the 73 assembly instruction manual (AIM) and pay specific attention to the coupe body build diagrams, including the birdcage. Compare those with the stock convertible build, often on adjacent AIM pages. At that point you will know what has to come off the coupe and what will need to be added for your swap.
If you are careful when removing coupe parts, you may be able to sell them or swap them for some of the convertibles parts you will need.
This one has popped up on eBay a couple of times; not sure it ever sold for what the seller hoped.
Not a '73, but the swap is the same.
Old Aug 24, 2011 | 07:57 PM
Nasty73's Avatar
Nasty73
3rd Gear
Thank you
Old Aug 24, 2011 | 08:02 PM
Clams Canino
Here's the thing.
'73's are a "one year off" car. So if you fix the nose right and paint it the factory color - the NOM Big Block won't kill your resale too badly.
I still say you'd do better to flip the '73 and start over with one like in the picture - thay can also be had very cheaply.
-W
Old Aug 25, 2011 | 12:43 AM
milo30's Avatar
milo30
I'm still working on the 78 conversion. Mine has been a PIA because the fiberglass didn't fit and I am having to do some altering to it. My advise would be what others have said, sell it and buy a convertible. You can find an old convertible body sometimes being parted out pretty cheap.
There are some that have been completed. I have links saved but not on this computer. If I had it to do over again I wouldn't do it. I am too far into it to turn back. Once I finish it I will be happy but it has just kept my car in the garage for the last 2 years trying to get the time to do the work. One thing leads to another and now I am pulling the body off and starting with a freshly painted frame. I will have a lot of time invested but not really that much money. I have shopped and found everything used so I kept my $$$ way down. I just have never done fiberglass work before and it is a learning process.
Make sure that you have the proper motivation before you start it. If you need any help I'll offer what I can.
Old Aug 25, 2011 | 03:26 AM
WESCH's Avatar
WESCH
Hi
I know of a 82 vert perfectly done, nice car.
But I also saw a 77 vert that had no softtop, only hardtop. They didn't use the complete vert *** end , so a soft top would not fit.
Don't know why one is going through all the hassle of converting and then misses the soft top installation. Unusable car without.
No way you can make a full day trip over here like this. Even if the sun is out in the morning and the weather forecast is great, one will return in the rain in the evening. Murphy's law.
If you go for it, do it correctly. It is possible as there are several conversions around.
Rgds. Günther
Old Aug 25, 2011 | 11:19 AM
Mashman's Avatar
Mashman
Here is a link to the thread mentioned earlier - http://forums.corvetteforum.com/1578415253-post6.html
If you really want to go the conversion route, maybe you can look into that convertible t-top, and let everyone know how it works. I think there has been a consensus that it appears to be rare, and even better, it looks cool!
Old Aug 25, 2011 | 03:16 PM
Fast81's Avatar
Fast81
Originally Posted by Clams Canino
Here's the thing.
-W
IDK Clams- Most 78-82 conversions i've seen go for $14-18K (like the one pictured above). I watched them for 2-3 yrs. hoping to one day snag one.
As i knew i was going to drop an LS/4L60 combo in and do a custom interior, i was thrilled to find an 82 already done in primer for under $5K - it drives so i have an engine/trans to sell off and the trans setup is identical for the swap.
IF i had wanted a pre-75 vert, i would have just looked for a beat up original ragtop instead of trying to swap a coupe into one as GM already made some.
Old Oct 1, 2011 | 02:45 AM
ikwhite's Avatar
ikwhite
A little late but, I'm doing a 77 big block, convertible conversion plus a whole lot of other mods. I'm of the thought you can do what ever you want, as long as you have the time, place, enough dough, and enjoy doing it. . Good luck and feel free to PM me with any questions, I'll try to answer them.
http://forums.corvetteforum.com/album.php?u=213691
www.vettemod.org
ikwhite
Old Oct 1, 2011 | 04:09 AM
ikwhite's Avatar
ikwhite
You can also look at this thread were seventysixvette posted links to his convertible conversion and some other members also posted.
http://forums.corvetteforum.com/c3-g...ible-chop.html
ikwhite
Old Oct 1, 2011 | 04:26 AM
Clubby99's Avatar
Clubby99
http://cgi.ebay.com/ebaymotors/Corve...c5f003918#shId
Cheap rear convertible clip
Old Oct 1, 2011 | 05:07 PM
Clams Canino
Sorry.. I meant that the sale of a "clean" mostly correct '73 would finance a do-it-yourself conversion project on 80-82. Not a finished car.
-W
Old Oct 1, 2011 | 07:35 PM
milo30's Avatar
milo30
Since you are dealing with a '73 it is much wiser to sell what you have and buy a fixer upper convertible or maybe find one being parted out and buy the body/frame. Not worth the hassle and expense for a year that there are already ones made. Now if you wanted the later 70's to early 80s looks in a convertible then go for it.
It is alot of work to track down all the small things that you will need and aren't reproduced. I bought all my stuff used so the cost has been kept down but it takes a long time to track everything down.
To c3 convertible conversions
Old Oct 2, 2011 | 02:09 PM
seventysixvette's Avatar
seventysixvette
Milos right, it takes a while to gather up parts for a conversion. The rear clip above is extremely interesting. I had this much money in my rear deck, hinges and hinge brace.
I'd do my conversion again though. It was a lot of fun and I learned a lot about the car.
It was something interesting to do. Some install LS engines, some install Tremic transmissions, others turn their doghouses into full tilting front ends.
They're just cars. Modify 'em and drive 'em like you stole it, or restore 'em and cherish 'em like a child.
But enjoy whatever you're doing.
John
You have to do a little research too. Some parts like deck hinges were different year to year. Decide whether you are going early or late C-3 convertible before you start.
Old Oct 2, 2011 | 09:16 PM
milo30's Avatar
milo30
How ya been seventysixvette? Haven't seen you around in awhile. I'm still working on my conversion. Tons of things have put it off for way too long including pulling the body off and start from the ground up now.
I wish I just had more time. I'd like to see some pics of what yours looks like now.
Old Oct 2, 2011 | 10:08 PM
Kavinsky's Avatar
Kavinsky
also with converting a convertibile you want to make sure that someone has stiffened up the body so it wont flex like a mad man in the back where you cut the top off.
