Rear frame gusset question
With the body off and the frame partially stripped I note the driver side rear frame gusset to be "different" than the pass side. It seems to be bent upwards.. however, there are no unusual creases or signs of blunt force (through the sombrero bracket).... the overall profile is horizontal ..looks fresh off the die... Can someone confirm if these bracket are identical pass side to driver side relative the position or location of the sombrero pocket?
Thanks in advance
