Quick carpet question?
Old Aug 25, 2011 | 03:01 PM
Clams Canino's Avatar
Clams Canino
Default Quick carpet question?
On a 68 with just seat belts. Does the tunnel side seat belt stud poke through a hole in the rug - or do you bolt up the belt behind the rig and run it out through a slot? What's correct?
-W
Old Aug 26, 2011 | 02:05 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
the AIM should give you the proper mounting position. on my 78 the belt mounting is outside the carpet (mounted OVER the carpet) with the bolt head and bracket exposed if that helps you any.
