We know we talk about it all the time...about how to jack up the car properly and safely. I had the car up on all four jack stands today working on the car and I swear it freaks me out every time I do it.
Aside from a lift (I'll save that for next house) what else do you do to provide that little extra bit of precaution when you have her on stands?
A million things go through my mind...what if one of the jack fails and then that puts more stress on the other jacks and they all fail, or don't pull/tug too hard as you don't want to shake the car, etc.....
Never had a jack stand fail yet.I do inspect them.Odds of one failing are slim unless you keep outside in the rain and rust eats it up.Always use the heaviest one I can fit underneath it.
Hi FS,
I've always been concerned about a j-stand failing or knocking the car off the j-stands somehow.
Since I'm almost always in the garage by myself I always take the time to take the wheels off and push them under the corners of the car.
I figure that gives me about 10" of crawl space under the car if I need it.
Just today I had just one jack stand under the car and one wheel under it too.
My wife says she's glad I take the time to do it since she's the one who'd need to clean up the mess.
Regards,
Alan
Like you, I was worried about jack stands (I hope you meant jack stands and not jacks!!!!) so I built some ramps and hard stands. I used 1" square thick walled steel tubing and angle iron at the bottom. The tops of the stands measure 12 x 24" and the bases 18 x 36"and they stand about 18" high. They are joined by "connectors" that I made from 1" square steel and marine ply and I have three stands and two connectors on each side of the car.
Once the car's wheels are on the front and read stands, I can remove the connectors and the middle stands so that each wheel is supported by one stand as described above. Then I can safely work under the car without any fear of it rocking or falling.
Because of the flared build of the stands, they stack into each other and don't take up much room when not in use. I've got to post photos to show their construction.
Several years ago a friend gave me a couple boxes of 4x4 wood, cut one foot long. I put 3 of them side by side, then 3 more on top of those going the opposite way (90 degrees) and so on as needed. I then slide 1x4 or 2x4 in to fill out, so the wood "pillar" is under some solid part of the frame near where I'm working. If something should give, the car will only be able to drop less than an inch before encountering that. This is in addition to actually supporting the car on jack stands.
It's well worth the extra few minutes it takes, for my peace of mind. I have heard of hydraulic jacks blowing a seal and dropping suddenly, and would never trust one of those if I was going to be under. Cars can and do shift sometimes as we work on them, so anything you can do to protect yourself is wise. In most cases, you won't get a second chance.
2nd cousin is a mechanic by trade who also works after hours in his garage. He was in a hurry , hydraulic jack tipped and pinned him under a car. Damn near died. He was able to use his cell phone to phone his wife who came and got him out and took him to hospital. He ALWAYS uses jack stands now - even when in a hurry or for a quick job.
Hi FS,
Regards,
Alan
