Ls Motor swap cost?
There are a hundred ways to skin this cat. Check the LSx swap thread in the tech area of this forum, check the conversions and Hybrids section of LS1tech and just do as much research as possible. That's how you will make the right choices and save some coin.
If you want someone that's done it a few times, Josh at Custom Image is a good guy. He's helped me with a few aspects and also modified my water pump (necessary for the swap). His contact info should be here somewhere. If not, he's really big over on DC.
But if you have more money than you know what to do with, simply figure out what you want and cut the check for some guy to do it.
Seriously I have riden in some real ground pounders that drive way better than any Gen1. Case in point my brother in laws 67 LS7 powered resto mod. Look up 1coolc2 here on the forum for his specs. He just added morepower but I drove it with 530 RWHP and it was very cival in normal traffic but will pin your eyeballs when stepping on the loud pedal. He just redid the motor and now makes 598 RWHP. I am currently building up an LS3 with about 530 flywheel hp and have driven this motor in a newer Vette and the low down torque and high end HP is no match for my current 383 motor with 500 flywheel HP and mine is pretty quick. Cmon over here to the states and see what is happening. In a few weeks there is the LS fest in Bowling Green, this is where the serious guys come to run. 40+ years of technology over a Gen1 is a huge improvement. Nothing like nostalgia of the old motors but for performance the LS motors have it all over the older ones.
It is impressive how cheaply you can make power from LSs I'll give them that. My buddy's 500hp cost him a bit over $6k, and everything is a lot more expensive down here (I don't know how much he did himself but not much I'm guessing). Up from about 350hp in the stock car. That's an LS2 btw.
Do you have any good links to some dyno sheets where I can check out the torque at various RPMs?
I think with constantly variable valve timing you have to nail the throttle a bit more to let the ECU know you wanna go for it, whereas the older motors just assume that all the time (even when you're trying to save fuel...).
But, you take a gen 1 or gen2 small block, put on a better head, intake and cam and you will pump up the hp to the same levels that a hot LS gives you.
The best part about an LS engine is that it takes very little work to really push the hp up. A simple cam change and cyl head porting really wake it up. But that isn't to say older engines are obsolete.
I have 5k into my build. That's having it assembled by the shop from new pan to new intake. All forged stroked lower, studded main caps, roller cam, lifters and rockers, new aluminum heads. And it's a drop in. Just try and put an LS into any car that didn't already have an LS in it for that price.
If your goal is to just have an LS damn the cost, great. I'm sure you will be really happy. But myself, I'd rather that I be able to have great performance at a very reasonable price. Plus, it is the original engine.
Freshen it up $3G
Can't do it yourself ? Add $10G labour.
What you get? An car that'll make you 27 miles/gallon
How about looking around and buying someone elses LS1 - C3 vette. There was one on the forum for sale for $18 not so long ago.
Very nicely done too ! They can be had - you just have to be patient.
My 383 gets 24m/g. LS power is cool , but for 3m/gallon difference - is it worth it? You have to be doing AN AWFULL LOT of mile to make it pay.
. Anyway,I think that sort of hybrid is definately the way to go. I'm debating whether it'd be cheaper/produce similar results if I just went forced induction on my old smogger and use the low compression ratio to an advantage. I'd be doing all the new heads and everything.
Where in the US does one search for used performance motors other than ebay? As is being said, it's always cheaper to get one someone else has already done
You want a hot little SBC with some good power (400hp+)? It can be done cheaper.
You want an OD transmission? It can be done cheaper.
You want fuel injection? It can be done cheaper.
You want all three? Well, now an LSx swap can get you there at a competitive price. And if you really want to build some serious, no-compromises power that can be street driven effortlessly, the case becomes stronger for an LSx swap.
Can you do all three with and SBC or BBC? Yes. Can you do less than all three and still warrant the LS swap? Sure.
It all depends on what you're after and what you want out of the swap; either another Gen I or an LSx.
http://www.summitracing.com/parts/EDL-2216
(from another thread).
