Good tutorial for removing smog stuff
Old Aug 29, 2011 | 03:42 PM
gregmuzila's Avatar
gregmuzila
Default Good tutorial for removing smog stuff
I have a 78 corvette. Got rid of my cats and heat riser so far. Next up is the air pump and EGR (and whatever else you guys recommend)
Is there a good tutorial out there for what specifically to remove, and how much plugs/wires to remove and what to plug each hole/wire/plugs with?
Would like to pick up my needed parts ahead of time to simplify the project and read a tutorial or photo walk thru ahead of time so I am more familiar with the project.
Old Aug 29, 2011 | 04:34 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you will not gain anything but looks when doing this
Old Aug 29, 2011 | 05:56 PM
hunt4cleanair's Avatar
hunt4cleanair
And its illegal in most states...but I'll buy your parts!
Old Aug 29, 2011 | 06:04 PM
fauxrs's Avatar
fauxrs
Not entirely true, though the OP talks about "Cats" plural as if there were more than one, removal of the original pellet style pancake cat can indeed show a significant gain over the factory setup. Of course the same gain would be had if that original cat was replaced with a new high flow monolithic one as well.
Old Aug 29, 2011 | 06:05 PM
Nowhere Man
its still nothing your going to feel while pushing the go fast pedal
Old Aug 29, 2011 | 06:49 PM
fauxrs's Avatar
fauxrs
Maybe, maybe not, the May 1978 issue of Hot Rod reported that when GM was putting together the pace cars for indy they found that on car #0002 that the biggest boost of hp came from removing the catalytic convertor, it was worth 20hp. just short of 10%. Other changes were made to #0002 but none added up to more than that one change.
Car#0001 was the actual pace car used in the race and 0002 was the modified mule vehicle.
Of course these cars are now much older and the improvement is likely to be less since its not combined with the other changes that were done to the mule car, but it not unreasonable to assume that the change could be felt.
still overall your point is right on the money, there is usually nothing but looks to be gained when eliminating emissions componants.
Old Aug 29, 2011 | 07:18 PM
vettebuyer6369's Avatar
vettebuyer6369
...and I spent over a grand putting mine back on...
Don't throw the parts away!!
Old Aug 29, 2011 | 08:56 PM
gregmuzila's Avatar
gregmuzila
ya i am not going to throw away anything even tho the money is tempting.
i know it wont give me any HP gain. the air pump squeels and drives me nuts. Would rather get rid of it along with other stuff to clean up the engine bay a little.
I am just a n00b, so I wanted to see if there was a walkthrough so I know what to purchase and whatnot.
Old Aug 30, 2011 | 10:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Money well spent. Simply delicious.
Old Aug 30, 2011 | 10:31 AM
fauxrs's Avatar
fauxrs
There is no walkthrough that I'm aware of, for the most part its pretty straightforward. Think of this as an opportunity to put together the walkthrough and then post it up for the forums consumption. So long as you are not labroing under the misapprehension that there is all sorts of power to be found there (many do so labor) then you are going in with your eyes open.
On the other hand Vettebuyer has shown how a correctly equipped car can still be attractive.
Old Aug 30, 2011 | 10:44 AM
gregmuzila's Avatar
gregmuzila
right now I am just going to remove my air pump pulley and belt (it squeels constantly).
if I end up doing it, I will put together a nice tutorial since I searched so many threads where people are asking about what size plugs to get, etc.
Old Aug 30, 2011 | 11:13 AM
gregmuzila's Avatar
gregmuzila
anyone know what size these are? I figure I could take my tubes with my to store to make sure I get the right plugs.
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={55FFCC47-B0D7-41A3-A746-FFDCC4438277}&gid={42F08256-8D53-4543-9777-A551ECE31641}&pname=66-82+Exhaust+Manifold+A.I.R.+Hole+Plug+Kit &Referer=&Alias=&ptct=SGR-SR&CTitle=&
Old Aug 30, 2011 | 05:36 PM
vettebuyer6369
If it squeals, just remove the belt.
To Good tutorial for removing smog stuff
