Engine detailing supplies/procedure
Old Aug 30, 2011 | 08:35 PM
33Chevy's Avatar
33Chevy
Default Engine detailing supplies/procedure
Looking to detail my 82 engine compartment and wondering if anyone sells a kit that you can recommend.
thanks
Old Aug 30, 2011 | 08:43 PM
gregmuzila's Avatar
gregmuzila
I brought Meguiares engine bay detailing bottle, haven't used it yet as I have been to lazy to venture into the cleaning of the bay.
Make sure you cover up important stuff, others will chime in with exacts
Old Aug 30, 2011 | 08:45 PM
markids77's Avatar
markids77
There's no kit I am aware of, but you will want some spray engine degreaser, a parts washing brush for the really crusty areas, some carburetor cleaner for the fuel related areas. A roll of aluminum foil is invaluable for easily masking off hoses, wires and whatever else you want to keep paint off of... simply wrap it and spray. A couple cans of matte black, some engine paint a roll of blue painter's tape and perhaps some new valve cover gaskets would be a good shopping list to start. Once you get started you will likely see other areas (like the brake master cover and the headlight vacuum canisters) which look best in another finish than black... get an Eastwood's catalog and look around a bit... they offer an amazing array of specialty finishes so you can get as detailed as you wish.
Old Aug 30, 2011 | 10:44 PM
1974ta's Avatar
1974ta
It all depends on how nice you want the engine compartment.
I ended up taking everything off of my 70 that I could unbolt before cleaning. It really made the job much easier. I cleaned up each individual part and painted where correct before reassembly.
I also did not use a spray on degreaser right away. I used plastic putty knives and a lot of wire brushes to get most of the grease and grime off.
Then I used plastic brushes with a simple green type product to get the remainder of the dirt and grime off.
I then carefully masked everything off to paint the motor. I prepped one last time by using lacquer thinner to make sure it was all clean and ready for paint.
If you are just looking to clean up, use the spray on cleaner and a few brushes. The spray on does not work as well as one might think without scrubbing.
Have fun. It is definitely worth the effort every time you pop open the hood
Old Aug 31, 2011 | 12:15 AM
sly vette's Avatar
sly vette
As recommended above, Eastwood will have all you need except the effort and patience!
I have found that all their materials I have purchased are of good quality.
Old Aug 31, 2011 | 04:07 AM
hunt4cleanair's Avatar
hunt4cleanair
Old Aug 31, 2011 | 07:39 AM
gregmuzila's Avatar
gregmuzila
what should be covered with tin foil prior to spraying?
Old Aug 31, 2011 | 10:11 AM
7T1vette's Avatar
7T1vette
If the engine & compartment is a greasy, grimy mess, you only want to cover up items that can be damaged by your cleaning procedure. Electrical wiring needs to be cleaned also. Only cover it up if you are using a pressure washer and/or pressurized steam cleaning.
You probably want to remove the air cleaner...so that the element doesn't get soaked and that nothing goes into the carb. You may want to cover the distributor and put a plate or cap on the carb to keep stuff out of the intake.
The easiest way to get the 'heavy' stuff off is to buy some good engine degreaser and take the car to the local quarter car wash. Soak the engine, etc. down with degreaser; wait 10-15 minutes and wash off with hot soapy pressurized water. You may need to do this 2 or even 3 times to get the difficult stuff off. But, that's better than using a scraper and/or toothbrush to get that grime off.
Old Aug 31, 2011 | 11:56 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Exactly what I did with my 82...as a final touch I used Meguiar"s Vinyl & Rubber Cleaner/Conditioner & Wenol metal cleaner/polish....here's the end result.
Old Aug 31, 2011 | 12:30 PM
80malibu's Avatar
80malibu
Along with the engine bay, the area that houses all the wiper linkage below the windshield (on my '80) looks like GM put a black sealant in there with a fire hose. It cakes the WSW fluid supply lines and a vacuum hose. It looks like crap, is it best to leave it alone or is there a safe chemical to clean it up, or is the seemingly gross amount necessary for sealing the car properly?
Old Aug 31, 2011 | 01:01 PM
BFI6603's Avatar
BFI6603
If that bothers you, theres always the windshield wiper cover that vendors, like Ecklers, sell. Can even be painted to match your car-Pete
Old Aug 31, 2011 | 01:41 PM
80malibu's Avatar
80malibu
That looks good, thanks for the heads up.
Still wouldn't mind doing a general tidy of the area, I even found a couple of the rivet pins, or the rusted remains of them, that the assembly guys left behind in there. Amazing!
To Engine detailing supplies/procedure
