Analog Clock Runs Fast?
Old Aug 31, 2011 | 07:51 AM
Clams Canino's Avatar
Clams Canino
Default Analog Clock Runs Fast?
Any way to adjust it down a little before putting the dash back together?
-W
Old Aug 31, 2011 | 08:04 AM
Ganey's Avatar
Ganey
The clock adjusts speed when it is set forward (faster) or backwards (slower).
Old Aug 31, 2011 | 08:10 AM
Clams Canino
Most Impressive!! Thanks!
-W
Old Aug 31, 2011 | 08:27 AM
Clams Canino
It's not out of the cluster. And will be replaced with quartz if it ever fails.
-W (would rather not "screw with" a clock without any experience)
Old Aug 31, 2011 | 09:57 AM
7T1vette's Avatar
7T1vette
NEVER shoot oil into that clock mechanism. It will gum-up the works faster than Donald Trump can fluff his hair.
The process to 'adjust' the clock is to set the correct time (forget AM & PM...the clock doesn't care) on it and note the time of day that you made the adjustment. Approximately 24 hours later [give or take an hour or so], adjust it to the correct time again. Continue until the clock is reading accurately.
(The adjustment mechanism applies your change with the assumption of a 1 day rate change built into the mechanism. So, if you only adjusted the clock to the correct time every three days, you would cause it to over-correct twice the real error. If that confuses you, just make the adjustment at about the same time each day until it runs right.)
Old Aug 31, 2011 | 11:31 PM
phxjeeper04's Avatar
phxjeeper04
Wow....it never ceases to amaze me the info that is available on this site!! I did the interior of my 78 last week and when I removed the clock it was not working. But when I put it back in it was working, but very fast. One of the copper bands at the electrical dash plug was bent. I assume that is why it is now working after I straightened it out.
Old Sep 1, 2011 | 01:46 AM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Good writeup on cleaning and adjusting the clock.
http://pcfred.com/Vettetip/FixC3Clock.htm
To Analog Clock Runs Fast?
