Antenna Mast
Old Sep 2, 2011 | 11:04 AM
Ghoh's Avatar
Ghoh
7th Gear
Default Antenna Mast
I have a power antenna on my 81 and the mast is bent. Anyone know if you can replace just the mast or do you have to replace the whole unit? Thank you in advance for your help.
Old Sep 2, 2011 | 11:05 AM
gregmuzila's Avatar
gregmuzila
Depends, if it is original, yeah replace the mask.
if it is aftermarket, call whoever company it is and get a replacement mask.
Old Sep 2, 2011 | 11:33 AM
Ghoh's Avatar
Ghoh
7th Gear
It is original. So the search is on. Thanks
Old Sep 3, 2011 | 04:18 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Measure the diameter of the large mast section. A drill index works if you don't have a mike.
Most originals were 5/16", but some 'slimlines' and service replacements were 1/4",
Does your original have the rubber mounts on the mast tube?
Anyway, I have an NOS 1/4" mast available.
Old Sep 3, 2011 | 08:40 PM
golfradict's Avatar
golfradict
I had to replace the mast on my 1981 power antenna about a year ago, got it off of ebay for about $30.00, still works great, not difficult to do.
Old Sep 4, 2011 | 05:01 AM
Vette5.5's Avatar
Vette5.5
While not on older Vette's, have replaced power masts on other cars with Metra units quite reasonably. They claim not having to remove the whole unit, but do it anyway for a good clean up and lube. Also replaced whole units with Hoffmans from places like Crutchfield a few times.
To Antenna Mast
