Interior restore
Old Sep 4, 2011 | 06:59 AM
whitemule77's Avatar
whitemule77
Default Interior restore
some pics of interior restore my first time ever doing this. the savings was worth the hard work will have some pics of the seats being done later http://s1121.photobucket.com/albums/...ior%20restore/
Old Sep 4, 2011 | 07:32 AM
daytona yellow's Avatar
daytona yellow
Thumbs up...going to start mine soon
Old Sep 4, 2011 | 08:22 AM
Alan 71's Avatar
Alan 71
Hi wm77,
It looks like you're doing some very good work!
I like the REDLINES very much!!!
Regards,
Alan
Old Sep 4, 2011 | 09:33 AM
whitemule77
Originally Posted by Alan 71
Hi wm77,
Regards,
Alan
almost done want some chrome under the hood already have chrome valve covers to put on
Old Sep 4, 2011 | 09:58 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Looking good! I can't wait to redo my interior!!!
Les
Old Sep 4, 2011 | 10:00 AM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Looking good and those redline tires look great against the white paint
Old Sep 4, 2011 | 10:06 AM
whitemule77
Les
it was fun and when you are done you will say wow look at the money i saved
Old Sep 4, 2011 | 10:07 AM
whitemule77
thanks
Old Sep 4, 2011 | 10:57 AM
optiman's Avatar
optiman
Would you suggest someone with no mechanical expience to attempt replacing rug, 1979 l82? If so where would you order carpet from. How many hours did it take you to complete? I would want some kind of heat absorbing layer to put down first. My car gets damn hot where your feet go.
Old Sep 4, 2011 | 11:26 AM
oldsarge's Avatar
oldsarge
Looks great, always more rewarding when you do it yourself, well done !!!
Old Sep 4, 2011 | 01:00 PM
Alan 71's Avatar
Alan 71
Hi opt,
I'll leave the suppliers to others, but I believe most people can replace the carpet.
I think you'll need to take pictures as you remove the original, and remove it carefully so you can see how it was installed. Then after you put the heat barrier in, start on the carpet. Go slowly, and don't CUT ANYTHING until you've test fitted it and are sure of what you're doing.
Willcox for the new carpet?
Regards,
Alan
Old Sep 4, 2011 | 01:12 PM
whitemule77
you can do it i never did anything like this there is alot of good info on he internet for this. corvette america has alot of videos on this go for it. ordered all my stuff from ecklers they had the best deal for me ordered all new carpet door panels new foam for sets and new leather for seats
Old Oct 3, 2011 | 02:12 AM
erik.clark13's Avatar
erik.clark13
4th Gear
how much did your restore cost you? I am looking to do this also, but before I dive in, i would like to know how much im going to spend. Also, about how much does it cost to get your seats redone?
Old Oct 3, 2011 | 04:22 AM
whitemule77
it cost me 1100.00 seats and all order was 1500.00 from ecklers there web site had 10 or 15 percent off then i call them they took anthor 10 percent off so final was 1100.00 good luck if you need more info pm me with a phone num help morei
Old Oct 3, 2011 | 06:33 AM
rdroe's Avatar
rdroe
DC Area Events Coordinator
VERY good! I took everything out of the interior / rear interior and began. A suggestion on the center console tunnel and floor boards. Go to Home Deport / Lowes and get some chimney flash. It is a foil covered rubber that is flexible and has a a sticky backing on the rubber. I took off all the old foil from the interior, painted the tunnel and floorboards with a thick coat of Rustolium, then used 2 rolls of this foil and covered the tunnel and floorboards. Just like Dyna-mat for sound deadening, but easier to work with. $20 per roll. It also is a GREAT heat barrier. My feet are very comfortable on long drives. :-)
Just a thought ...
Old Oct 3, 2011 | 10:28 AM
VetteProject's Avatar
VetteProject
rdroe:
How did you get your SS t-top trim so shiny, did you replace it?
Old Oct 3, 2011 | 10:35 AM
rdroe's Avatar
rdroe
No, just buffed it with some Mothers on a mandril in my drill.
Thanks!
To Interior restore
