different clock question
Old Sep 7, 2011 | 07:01 AM
...Roger...'s Avatar
...Roger...
Originally Posted by Danish Shark
I think the clock (plus the before mentioned courtesy lamps) uses quite a bit of current, so with maybe 0.5 amps running through the bulb that will lower the voltage to the clock quite bit (because of the voltage drop over the inline bulb), which may or may not in turn cause a higher current draw.
Bottom line I don't think it will work.
You don't "THINK" it will work ? Sure it will.
The old type clocks wind every couple minutes and then run off a spring,a properly operating clock will wind through the bulb with no problem.
Not sure what your referring to about the courtesy lights.
One added bonus is every time you turn the **** and disconnect the battery,the small bulb monitors battery drain,if your car has battery drain problems the bulb will light up,otherwise the bulb will be out.
Old Sep 7, 2011 | 07:04 AM
...Roger...
Originally Posted by Willcox Corvette
Sometimes you just have to roll with it..
http://willcoxcorvette.com/product_i...ducts_id=27160
Willcox is pleased to have the original Bubbinator 2011. Our crack pot on the spot tech (located somewhere in the back hills of Ohio) has devised this newly fangled gadget! Not only will the Bubbinator 2011 solve a problem for you, but it will also cause hours of laughter for the next owner of your car. Gain your place in history, folk lore and fame in the Corvette Community with the Bubbinator 2011.. and if you act within the next thirty minutes we'll give you not one.. but TWO bubbinators! Yes folks... you read correctly! Two Bubbinators for the introductory price of $79.99. Act Now! ***
In thirty years someone will swear it came that way from the factory...
You rotten azz !
Old Sep 7, 2011 | 10:05 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by riverracer au
what if someone actually places an order for one ? ? ? ?
Some gal named Dawn just ordered two....
OMG... Roger jacked the picture back as his profile pic... ha ha ha
