Differentiall Confusion
Old Sep 5, 2011 | 08:27 PM
cviola2005's Avatar
cviola2005
Default Differentiall Confusion
I'm trying to research the differential in my vette because it needs a rebuild. I don't want to order the wrong parts but the information i find is indifferent to itself.
Advance Auto Parts tells me that it is an 8.75" ring gear. Two pieces of original literature found online tells me that it is an 8.375" ring gear.
Also, I thought the car had a 3.08 ratio. After researching the differential housing identification stamp, it says it a 1976-77 housing with 3.08 gears. But after disassembly, the pinion has 10 teeth. According to the 1974 Chevrolet Corvette Specifications literature i found online, it says that the 3.08 ratio should have a 12 tooth pinion.
Both ratios have a 37 tooth ring gear.
What do I have????
Old Sep 5, 2011 | 08:40 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
What do I have????
If your have it disassembled, then just count the number of teeth on the ring gear and divide it by the number of teeth on the pinion gear. That is your ratio
I would not use Advance for parts info.
Go online to vendors on this forum like Willcox, Corvette Central, Jegs, Summit, Van Steel, etc if you want good info.
Good luck
Bman
Old Sep 5, 2011 | 08:53 PM
cviola2005's Avatar
cviola2005
Good luck
Bman
Thanks. its a 10 tooth pinion and a 37 tooth ring making it a 3.70 ratio.
I don't believe Advance on any information anymore. Seems like alot of parts I buy from there for the vette are wrong. So I will believe the two pieces of original literature saying that it is an 8.375" ring gear.
Old Sep 5, 2011 | 08:55 PM
bmans vette
Exactly
Old Sep 5, 2011 | 10:20 PM
cviola2005's Avatar
cviola2005
the code on my housing is OA W296 E1
so not only has someone changed the entire differential, but also changed the guts of the differential???
Old Sep 6, 2011 | 12:19 AM
dboz's Avatar
dboz
Welcome to the world of 35 year old cars. A lot goes on in that amount of time.
Old Sep 6, 2011 | 01:24 PM
Rally68's Avatar
Rally68
I pulled the 3.08 out of mine and put in 3.73s; from what I understand, it is/was a fairly common performance upgrade...I have a chart somewhere that shows that a 3.08 to 3.73 gear swap increases torque to the rear wheels by 21%. (It also reduces fuel economy by a gazillion percent ) If your gears need replacing, I recommend US Gears from Tom's Differentials. Here is a pic with the original gears on the left and the new ones on the right:
To Differentiall Confusion
