C3 Noob-First Post
I'm new here. My name is Ross, and I live in PA. I found this forum because I've been putting off getting a real car for too long. I got married, I finished grad school, got a job, got a house, and the time has finally come (I hope) to get the car I always wanted: a C3. I've read some of the buying guides on here, and have gotten a deeper understanding of the car, but some very basic questions remain, and I hope you all can help me sort them out. I know about the suspension problems/need for replacement, about the birdcage rust, and I understand the numbers-matching thing. Here are my other questions:
1. Mechanics. My grandfather was a GM employee and never went to a mechanic in his entire life. My dad put himself through grad school as a mechanic, and I only ever remember him taking a car to a mechanic to get the engine rebuilt. I learned a lot from these two, but I'm still young (26), and my tools in particular are very limited right now (haven't built up a collection yet). If I got up against it with a problem I couldn't fix, do normal mechanics still work on C3's, or are the parts for them broadly unavailable except 2nd hand?
2. Reliability. A lot of C3's that look like they're in good condition seem to be "trailer queens." I have a short (7 mile) commute, and was kicking around the idea of driving it every day. If I don't take it to work at least some of the time, I doubt I'll get the chance to drive it very often. My weekends are quite busy because of the line of work I'm in.
3. Model type. I'm very partial to the early and mid 70's models, but not so big a fan of the ones from the early 80's (bubbled back window). Is there anything in particular that I should be holding out for on these cars (special engine, etc.), or should be avoiding like the plague (one particular model year, etc.)?
Thanks.
http://www.amazon.com/Corvette-1968-...5669981&sr=1-3
The '68 has a lot of "one year parts" that make it a little more difficult and costly for parts. The '69-'72 have chrome front and rear bumpers (73 has chrome rear bumper only). The '68 and '69 also have the side louver gills as opposed to the check box style. Lots more than this but have to run. You also need to figure out of matching #s is important to you - cost more but possibly a better investment (big debate on here about that). If you are looking for a daily driver I would suggest getting a car with a crate or not matching #s as you will save $s and be able to enjoy it more. I bought matching #s and original but in hind site probably should have saved $5-$10k or so and bought a NOM. Best of luck and get ready for a lot of help from this forum.
I am fairly new to the C3 world and recently bought one in very similar circumstances as yours. I wish I would have read this book prior to buying. As it turns out, I bought the perfect car for me, but the book has great information about the model changes from 68 to 82. Great book. Good luck with your search. --Sam
Thinking of a NEW old Corvette!!!! NICE!
About your tool question..... if the car has it's original, (or original type), engine, a couple of tools, (or pieces of equipment), that you'll need, that most mechanics don't use anymore, are a timing light and dwell meter.
About your parts question..... the vast majority of mechanical parts are still readily available. It's the trim, appearance, and interior items that are becoming more difficult to find. Many of the reproduction parts that are being made aren't very good. For this reason many people are finding that buying a very complete car in good condition is worth the extra cost up front.
I think you'll find the late 60 early 70 cars are VERY easy to work on with the help of the GM CHASSIS SERVICE MANUAL, and the GM ASSEMBLY INSTRUCTION MANUAL, that are available for each model year.
Good Luck!
Regards,
Alan
Taking it to work is a good way to get to drive it more often. I'm retired, but I drive mine a lot more since I started running errands in mine.
Welcome to the forum. Finally seeing the sun there in PA yet?
Try to find the best condition car that fits within your budget. Being your first C3 and you want to use it as a daily driver, you need to find something that is reliable and pretty much sorted out. While cosmetics may draw the oohs and ahhs from admirers, you need to give emphasis to the mechanicals. A sorted out car will probably look good too, but just don't go for the shiny new paint and interior while the rest of the car is a pig. You will get more car for your money if you buy a coupe. If you want a removable rear window, look no later than '72. The 4 speed is the way to go. You might want to consider a NOM car with a newer crate motor and most all the suspension and other mechanical stuff already taken care of. That way you can enjoy driving the car while you decide whether or not to move up and spend more of your money. Good luck with the hunt.
Dennis
since you are in PA, it is likely you are looking for a local car.
I have seen may pictures of Northern cars, and I am familiar with the weather conditions in PA. Hence I suggest you look further away from home, even thought there are some large specialist sellers in your state.
I bought a CA car, which needed a repaint, because the still original paint job was dull, and damaged by the sun; BUT the car is entirely rustfree!! That is extremely important for this model.
On top of that, the car is very original ('81), which is not what you are looking for.
Hence I would suggest to try to find an Southern car between '73 to '77 which are not too expensive yet, and would be a nice daily driver.
Have fun!!
Cor
If you want simple, no emission components to speak of IE catalytic converters, you may think about a 73. No wiper door, no fiber optics, no catalytic convertor, dual exhaust. The down side is no removable rear window. If you don't mind possibly, needing to tinker, 69 - 72 would be my next recommendation, only reason I don't include 68 is the one year parts. I'm partial to the 70, removable back window, fiber optics, wiper door (mechanics of it doesn't bother me), high back seats, etc.
A NOM will be cheaper than a comparable numbers car. Coupe cheaper than Convertible. If the NOM is a relatively new engine, reliability may be better. Nice if it came with modern systems like fuel injection but I haven't seen any personally. The original engines were not terribly fuel efficient. I swear I can see the gas gauge moving down as I drive.
You should be able to do most of the work yourself. Everything takes twice as long to fix on a Corvette, compared to other cars, since many parts aren't easy to get to. They weren't built for ease of maintenance. Most parts are available from Corvette parts suppliers. As someone mentioned earlier, the quality of reproduction trim parts are generally poor. They're expensive to paint as well. I agree with Faster regarding putting the mechanical condition high on the list. If a seller is flipping the car they'll most often skimp on the mechanicals and just pretty the car up. Been there, no fun at all... Paint would be my next priority after mechanicals.
I might add that I am working on a 76 with basic tools. I am adding a few as I need them, but most of the tools are ones you either already own, or should anyway. There are a few specialty tools that you will need like pullers and such. Most of the big auto parts stores will loan them out. You just buy it, use it, return it. I have a steering wheel puller right now from Advanced Auto.
Good luck!
I drive mine regularly, but I do NOT consider it a daily driver. I've got a 2010 Ford Focus for that. I drive the Corvette everywhere though. It stays in when it rains, and will never see snow. If I want to work on it doing something that may take a few days it's no big deal. I can drive the Focus on sunny days if I have to..
My advice is to always have a second car such that the Corvette can be the car you drive when you want to drive it rather than when you have to drive it.
If you have another car you'll find that working on the Vette is relaxing and rewarding. If you only have the Vette (and have to get it up immediately) you'll find working on it to be stressful and frustrating...
great to have you. I'm sure you will read all these posts and study them carefully, I haven't yet but thought I might have something helpful to add. I'm 34 now, but bought my C3 when I was 27 and wanted to drive the heck out of it because I have wanted a corvette since I was about 10. I made a few right choices and got a few tough breaks. I targeted a car from the south because we use salt on the roads up here (Chicago) and everything is pretty well rusted out. Here's kind of how mine shook out:
year: 1974 (first non chrome bumper car, flat back window, Stingray) - these are less costly than the chrome bumpers but I think still look tough if done right. I didn't know much about '74's going into my search, but I am very pleased with it
engine: crate GM ZZ4
Trans: TH400 (planned to change it to 5 or 6 speed manual, still do...)
Cooling Sys: Installed DeWitts with dual spals and new mechanical water pump because the stock unit couldn't cool the crate motor. Upgraded alternator to 140A at this time also
Brakes: seized on me after 3 months driving when a rubber hose collapsed. now all new stainless lines, rotors, calipers, etc. I did this in my garage but there were plenty of places I could have taken it.
Headlights: after market fixed kit installed prior to my purchase, installed relays recently to take load off dimmer switch.
Ignition: MSD with 6AL - unreliable at best. HEI is the way to go for a driver, but you need a tach drive for a '74
I've also done many other interior and dress up projects by choice like install blue LED dash lights, sound system with kick panel speakers and rear sub, new seat belts from a late 90's Trans Am, valve covers, etc. Most of these little projects won't keep you off the road and can be accomplished with a basic 150 pc or less tool kit and a few specialty tools, like a timing light and a multimeter. You will need to buy some wiring diagrams for the car, I like the Doc Rebuild pair I have and use them all the time.
I targeted a non numbers matching chrome bumper car but couldn't pass this one up because it had the paint, wheels and sidepipes I wanted plus a newer crate motor. Parts are plentiful (access isn't) and the crate motor makes it that much more reliable. I don't have to worry about smog equipment on it because I don't have to pass emissions in IL with a 25+ yr old car.
Check the body fit. I figured I would be able to adjust my hood to line up but I can't- at least not without major surgery. There is no vertical adjustment because the hinges sit on pads so mine has always sat high. If you see a flaw check to see if it looks fixable or is at least something that won't drive you batty every time you look at it...
This forum is a huge help! Seemingly unlimited expertise here
Good Luck!
-Dan
