1968 327 questions
Old Sep 12, 2011 | 12:10 AM
13611's Avatar
13611
Default 1968 327 questions
I'm about to set the motor on the chassis of this aborted project I picked up (1968 coupe). I would like the motor to look as original as possible. It's a numbers matching 327, but the builder put an old Edlebrock TM1 intake on it. What intake came on this engine? The engine numbers put it as the 300HP with a TH400. The internals of the engine were built failry extreme. I am also missing the exhaust manifolds. Were they the 2" or 2 and 1/2" outlets? What numbers am I looking for on the manifolds. Does anyone know where I could look at some pictures of a nice original setup? Other than the fact that the entire frame and suspension parts were powdercoated black and the TH400 is a correct year, non-vin matching numbers tranny... it's all there. Do I stick to original the rest of the way through? What is best for resale value? Thanks to all in advance.
Old Sep 12, 2011 | 10:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Good pics here:
327/300 base engine.
Original intake manifold was cast iron Q-Jet.
Corvette Blackbook lists additional specs.
Keep it stock.
Old Sep 12, 2011 | 10:02 AM
Rally68's Avatar
Rally68
The intake casting # for the 1968 327/300HP is 3919803
Old Sep 12, 2011 | 10:09 AM
Mike Ward's Avatar
Mike Ward
Exhaust manifolds were 2"
Old Sep 12, 2011 | 11:54 AM
13611's Avatar
13611
Thank you all for your help! I hope someday I can help others on this forum... But for now... I love the fact that there is an answer for everything here!
To 1968 327 questions
