Mini Starter Question??
Old Sep 12, 2011 | 09:29 PM
68vetteman's Avatar
68vetteman
Default Mini Starter Question??
I want to get a hi-torque mini starter and have 2 questions.
#1 Do you use the brace in the back of the starter like a full size OEM?
#2 Do these starters use a solenoid similar to OEM so I can use the stock wiring?
Thanks 68 Vetteman
Old Sep 12, 2011 | 09:41 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Mine was a simple swap. Same wiring, solenoid the same, then only two bolts to connect it.
Works on my big block very well.
Old Sep 12, 2011 | 10:42 PM
Lupigiato's Avatar
Lupigiato
Old Sep 13, 2011 | 08:53 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Some mini starters have only one small terminal. That would be used for the purple start wire. On the original there were two and the other was used for the 12 volt to the coil for starting only. The original wiring on 68 to 74 would have had a resistor wire that cut down the voltage to 9 volts (IIRC) for the coil when running. If you have removed the points on these years, you would have had to supply 12 volts to the HEI coil all the time, so the R connection on the solenoid is not needed, and that connection can be dropped ans taped off with this type of mini.
I did build a brace for mine mainly because I can. The original big starter will not work, it will be too short.
To Mini Starter Question??
