Engine Cleaning
Old Sep 15, 2011 | 01:45 AM
cviola2005's Avatar
cviola2005
Default Engine Cleaning
I have pulled out my motor for a complete rebuild. I have decided to change heads for a build I'm thinking about and the used heads I bought are covered in oil and dirt. I'm not interested in taking anything to the machine shop. So my question is:
What is the best cleaner for removing oil and dirt?
I have heard of using kerosene, gasoline, diesel and coleman white gas. Any opinions?
Old Sep 15, 2011 | 06:55 AM
Roco71's Avatar
Roco71
Any of those will work as cleaning solvents the issue becomes health, safety and environmental.
Wear protective gloves,petroleum products are absorbed into your skin. You are working with flammable products and what are you going to do with them when you are finished? You see where this is all going.
Old Sep 15, 2011 | 07:44 AM
imariver's Avatar
imariver
When I removed and rebuilt the front suspension components on my 73, I bought a plastic tub used for mixing cement, filled it with WD-40 and just let the parts soke. this softens up the grease and grime. It's a little more work, but it's safe to use, won't harm any parts and you can use it over and over again. But use rubber gloves anyway.
M2C Steve
Old Sep 15, 2011 | 08:45 AM
sstopczy's Avatar
sstopczy
I have had great results using Purple Power Degreaser. You can find it almost anywhere and it has very little smell.
Old Sep 15, 2011 | 09:42 AM
joewill's Avatar
joewill
'complete' rebuild but not taking anything to a machine shop?
a couple of cans of Gunk and an old toothbrush, then a powerwasher should do the trick
Old Sep 15, 2011 | 09:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by joewill
...powerwasher...
Yep. Or take them to the U-Squirt car wash.
Old Sep 15, 2011 | 10:19 AM
builder's Avatar
builder
I pressure wash my stuff. It's just easier.
Old Sep 15, 2011 | 10:37 AM
rdroe's Avatar
rdroe
DC Area Events Coordinator
I have found a little secret that a mechanic told me about many years back. The problem with grease & grime is that it just pushes itself around with most cleaners or you need a big production to get rid of it. Power washer, engine degreaser, etc. What I do to clean parts on the car, off the car is to use Brake Cleaner. It hits the grease, dissolves it as it runs off, evaporates so that there is no mess, and the *stuff* that it leaves behind is now a dry flakey substance that can be blown off with an air blast. I usually wait for sales from auto stores where I can get cans of it for $1.29. Then, using the little red straw and a catch tray, focus the spray on the greasy part. The runoff if any, goes into the catch tray. Then I hit it again and watch the clean part shine through. I've done my entire engine like this. I am tackling the oil pan replacement tonight. Going to run a shot of B-Clean around the bolts, get it nice and clean, then re-paint.
Just my .02 but worth a try.
Old Sep 15, 2011 | 11:15 AM
7T1vette's Avatar
7T1vette
Ohhh....the ozone layer!!!!
Oh, well. That method would get the job done.
Old Sep 15, 2011 | 12:09 PM
rdroe's Avatar
rdroe
?? How is that different than engine cleaner in an aerosol can?
Old Sep 15, 2011 | 03:02 PM
cviola2005's Avatar
cviola2005
thank you all for the replies. very good point about the flammable liquids. I don't think I'm going to use an of those. My brother-in-law told me about purple power and how good it is, but that was some time ago and I have since forgotten. I might use that and/or brake parts cleaner.
UPDATE:
After disassembly, I find a pretty significant lip at the top of my bores. Great, I have to take it to the machine shop and get it bored. So I'll have them clean the block and heads, and I'll clean all other components as mentioned above.
Old Sep 15, 2011 | 10:30 PM
jozf's Avatar
jozf
Simple green, Its the best that I ever Used. It does not hurt paint or stain metal and is
environmental friendly, also lots of power wash.......................Keats
To Engine Cleaning
