Engine ID
Old Sep 17, 2011 | 05:57 PM
Skip Burney's Avatar
Skip Burney
Default Engine ID
I just picked up a complete 327 today for free and was wondering if anyone can tell me what it is by the ID stamped on the pad. I have never seen a stamping like this one. It is T05I9KA. Thanks Skip
Old Sep 17, 2011 | 06:29 PM
Mike Ward's Avatar
Mike Ward
T=Tonawanda engine plant
0519= assembly date May 19
KA= might be a 265cu in from a 56 Truck. The casting date and number will confirm.
Old Sep 17, 2011 | 06:47 PM
Skip Burney
it`s a 4 barrel engine with 327 valve covers and came in a 68 Bel Air
Old Sep 17, 2011 | 06:53 PM
garage-ghost's Avatar
garage-ghost
Code Year CID Vehicle HP RPO Trans Carb Comments
KA 56 265 Truck 155 409 Manual 2-Brl Hydra
Source:http://www.chevymania.com/partsid/su...fm?block=Small
Old Sep 17, 2011 | 07:20 PM
Mike Ward's Avatar
Mike Ward
Sure it's not HA then?
Old Sep 17, 2011 | 10:51 PM
Skip Burney
I am pretty sure it is KA but what would HA be
Old Sep 18, 2011 | 06:30 PM
Skip Burney
This engine has a block casting number on the back drivers side that is 3858180 and the head casting numbers are 3774682. Anyone have any ideas? thanks skip
Old Sep 18, 2011 | 06:47 PM
bucky katt's Avatar
bucky katt
327, 64-67 passenger, chevelle, camaro these apparently had larger water jackets and thinner cylinder walls.
Old Sep 18, 2011 | 09:46 PM
Mike Ward's Avatar
Mike Ward
Low HP 327 block. KA must actually be HA. Need the casting date and VIN derivative to narrow down further.
Old Sep 18, 2011 | 10:24 PM
Skip Burney
Mike I have wire brushed the block stamping till this thing shines and I would swear it says KA. It has a stock 4 barrel carb and intake on it and the engine dosen`t look to have been touched so I don`t think it is a low hp engine. It came out of an old cop car.
Old Sep 18, 2011 | 11:32 PM
DJordan442's Avatar
DJordan442
It doesn't matter what intake, carb, or valve covers are on it. The codes tell the tale. All that stuff could have been added years ago.
Old Sep 18, 2011 | 11:48 PM
Skip Burney
It`s a small journal 327 with 1.94 heads and if this engine has been touched in the last 30 years you could fool me. I am surprised I can still turn it over. It was in a Georgia State Patrol car that was wrecked so I seriously doubt anyone would have added an intake, carb or valve covers to a wrecked cop car sitting in the back of a junk yard. It still had oil in the pan with no water in it as the hood was still on the car. I am just puzzled by the KA block stamping. I am planning on using it to replace the tired 283 thats in my 66 El Camino.
Old Sep 19, 2011 | 12:28 AM
Mike Ward's Avatar
Mike Ward
So how about it?
Old Sep 19, 2011 | 01:23 AM
Skip Burney
the casting number on the back of the block is 3858180 and the casting number on the heads is 3774682 the old car body is crushed by now
Old Sep 19, 2011 | 09:47 AM
Mike Ward's Avatar
Mike Ward
Jeeze, I'm just tryin' to help you here. Third request. The VIN derivative is on the engine pad next to the engine plant stamp.
Old Sep 19, 2011 | 01:20 PM
Skip Burney
Thanks Mike I know you are trying to help and I appreciate it, but thats the code everyone is telling me is wrong. It is T05I9KA and I have wire brushed it till it shines and it still looks like a KA to me.
Old Sep 19, 2011 | 01:43 PM
Mashman's Avatar
Mashman
There should be another code on the same pad with the 'T05I9KA' that is the number Mike is asking for. Or are you saying there is nothing on the pad other than 'T05I9KA'?
To Engine ID
Old Sep 19, 2011 | 02:29 PM
Mike Ward's Avatar
Mike Ward
There should be two, separate stampings on the engine pad. The one you've already quoted is the engine plant assembly stamp. The other stamp will a derivative of the original vehicle VIN and has a slightly smaller font.
The other info required is the casting date of the block (not casting number or engine assembly stamp) and is found on the rear upper flange of the block. This will appear as a single alpha character followed by three or four numeric. ex. A0168 or maybe A168 etc.
Old Sep 19, 2011 | 02:49 PM
Skip Burney
http://i773.photobucket.com/albums/y...20pics/002.jpg
Here is a photo of the pad so you guys tell me what it is.
Old Sep 19, 2011 | 02:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...you guys tell me what it is...
That's the stumper of the day.
