Vacuum hose question
Old Sep 25, 2011 | 05:15 PM
Fastclient's Avatar
Fastclient
Default Vacuum hose question
Question about a vacuum hose on my '79. From the intake manifold a vacuum line goes to a filter, to a check valve then splits to a large hose and a smaller hose. The larger hose then T's off again about a foot from the check valve on my car. A larger hose continues on to the air reservoir tank for the headlites and a much smaller hose goes over to the right side and thru the firewall into the cabin. I have looked but cant seem to find any mention of this smaller hose... where it goes and what it does. Anyone have any ideas? Thanks!
Old Sep 25, 2011 | 05:37 PM
'75's Avatar
'75
I believe the smaller hose through the firewall is for the heater a/c controls
Old Sep 25, 2011 | 05:40 PM
Lupigiato's Avatar
Lupigiato
On my 68 the smaller hose connects to my headlight switch so the lights rise.
Old Sep 25, 2011 | 06:30 PM
Fastclient's Avatar
Fastclient
Thanks for your reply,
On my '79 the smaller hose from the check valve goes to the switch to raise the headlights. The hose I am referring to is a smaller hose that T's off the larger one from the check valve. There is no mention of this smaller hose in this diagram http://forums.corvetteforum.com/c3-t...tem-works.html so I am at a loss
Old Sep 26, 2011 | 11:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Fastclient
...The hose I am referring to is a smaller hose that T's off the larger one from the check valve....
AC/fresh air system. The various flapper doors and selectors use vacuum. '75 saved you.
Old Sep 26, 2011 | 02:51 PM
Fastclient's Avatar
Fastclient
So if I was to put a vacuum pump on that small line it should it hold vacuum? Mine does not and I think that is a huge vacuum loss
Old Sep 26, 2011 | 03:34 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
http://willcoxcorvette.com/instructi...82_secured.pdf
Old Sep 26, 2011 | 03:41 PM
Easy Mike's Avatar
Easy Mike
I'm not sure it holds vacuum. It supplies vacuum. Can you hear a vacuum leak under the console? Are your AC, fresh air, and heat/defrost selector doors opening and closing (you can usually hear them open and close)?
Old Sep 26, 2011 | 04:55 PM
Peterbuilt's Avatar
Peterbuilt
Here is the hose going through the fire wall, you have to check from here back to make sure there are no leaks.
Old Sep 27, 2011 | 02:08 AM
7T1vette's Avatar
7T1vette
Adding a vacuum pump to a system that has vacuum leaks will NOT solve operational problems. If you have low vacuum, due to a radical cam and engine build...but the vacuum system is leak-free and still doesn't work...then a vacuum pump might be a reasonable solution.
Otherwise, find the leaks and/or defective components and fix them.
Old Sep 27, 2011 | 10:44 AM
Fastclient's Avatar
Fastclient
Sorry for the misunderstanding...
Didn’t mean to imply I was going to install a vacuum pump to replace or supplement the system. What I was curious about is if I was to draw a vacuum on the smaller line with a mity vac hand pump should the line hold a vacuum meaning if it doesn’t there must be a leak.
Old Sep 27, 2011 | 11:23 AM
Easy Mike's Avatar
Easy Mike
What are you wanting to do, Fastclient? You haven't actually said you have a vacuum problem. AC/fresh air system not working?
Old Sep 27, 2011 | 12:57 PM
69 Chevy's Avatar
69 Chevy
The whole system is a big controlled vacuum leak. MityVac is useful for 1 diaphragm at best, not half the system.
To Vacuum hose question
