While I was placing my Headers on I broke off the tab to the water temp. sender unit. I went and purchased a new one for a whoping $9.99 . Now my temp. gauge does not work. I disconnected the wire from the sender, and tested with a light. The tester light comes on so I know there is no break in the wire. Is it possible to get a bad sending unit new? Or is there a difference in the type? I do not think it has anything to do with the gauge backing. Since It worked prior. And I did not touch anything inside the car. What are your thoughts?
I'm pretty sure the sending units have a certain resistance you need to match in order for your gauge to work properly. You should be able to find a correct one from any of the Vette vendors.
Roger, I found a BWD #WT203 and a #WT203Z. Whats the diff. besides the price. The first one is $13.29 the second is $ 5.69.
The WT203Z is in stock. The WT203 is not!
I believe the WT203Z is OK but I can't remember for sure. Bring it home attach an ohm meter and put it in boiling water,if it gets down to 80 ohms it should be good.
