1970 corvette speakers
Sep 30, 2011 | 08:49 PM
hey did the 1970 vettes only come with front speakers or how and u tall if it had rear speakers i dont think my car did
Sep 30, 2011 | 09:25 PM
Front speakers only, from the factory. Unless you had some for the back seats.
Oct 1, 2011 | 12:05 AM
thats what i was seeing was fronts this web page has helped a bunsh lol thank you
Oct 1, 2011 | 10:00 AM
Cruise-In II Veteran
Sheldon: buy two or three of the Corvette coffee table history books; the pix are great and the text is informational.
Oct 1, 2011 | 10:20 AM
Hi Sarge,
I thought the rear seats came with a place to plug in your earbuds but not actual speakers?
Can you verify?
Regards,
Alan
Oct 1, 2011 | 10:36 AM
Quote:
Originally Posted by
Alan 71
Hi Sarge,
Can you verify?
Regards,
Alan
Alan the earbud plug was deleted in 69, you know that.....
Oct 1, 2011 | 03:10 PM
relay under the hood buzzing
hey think its the horn relay not for pos if it is, it is buzzing can pull the red black wire off and it stops it the relay bad or
Oct 2, 2011 | 10:27 AM
sheldonbaker
I am assuming it is only buzzing when the key is on, or does it do it all the time. Check your wiring to make sure all is connected right, and all grounds are good. You may have a short somewhere or it may be a bad relay, not really sure until you can confirm all your connections, wiring and electrical issues can be a troublesome matter.
Oct 2, 2011 | 11:09 AM
Seat belt warning. Wiith the key in the ignition, the buzzer will sound and the SEAT BELT tell tale will light.
Oct 2, 2011 | 06:52 PM
Easy Mike
seat belt light works with or with out the red light plug in ,,, my 1971 nova did the same thing i just left it un pluged
