Speedometer Cable
Old Oct 3, 2011 | 09:47 AM
81shark2008's Avatar
81shark2008
Default Speedometer Cable
My speedometer only goes up if i floor it and then in reverse it actually drops down and pegs!!!???? so i assumed a bad upper cable. The problem is I ordered on ein and it was 41 inches long. The one I took out was less than 2 feet. I have called every parts store and they are all the same. 41 inch upper and 63 lower. Was there an upgrade or change they made or am I missing something??? should i use the 41 inch one? seems like alot of extra i dont know what to do with through the firewall. thanks
Old Oct 3, 2011 | 11:08 AM
81shark2008
Old Oct 3, 2011 | 11:11 AM
Mike Ward's Avatar
Mike Ward
Assuming is bad. Confirming is good.
Old Oct 3, 2011 | 11:21 AM
81shark2008
thats what i am trying to do. thats why this whole thread was started. im not sure if i have the right cable to even try to confirm it with
Old Oct 4, 2011 | 02:24 PM
Rick_V's Avatar
Rick_V
Here ya go http://cgi.ebay.com/ebaymotors/1969-...#ht_1281wt_724
Old Oct 4, 2011 | 02:32 PM
Mike Ward's Avatar
Mike Ward
The upper cable is rarely bad. How do you know it's not the drive gear in the tranny, the lower cable, the the c/c module or the speedo head itself?
To Speedometer Cable
