Trailing arm bushing install question.
Old Oct 8, 2011 | 09:36 PM
C3Dave's Avatar
C3Dave
Default Trailing arm bushing install question.
How much flare do I need to put on the sleeve, (tube) to correctly hold the bushing in? I can't imagine it needs to be the same as the flare on the factory end. Any insight would be appreciated.
Old Oct 8, 2011 | 09:54 PM
C3Dave's Avatar
C3Dave
Wrong forum. Reposted in C3 Tech
Old Oct 8, 2011 | 10:13 PM
Steve2147's Avatar
Steve2147
I just finished doing a set yesterday. The tool I made was from 3/4" stock which made my flare just over 3/4" outside measurement. If you look at the size of the hole in the washer that fits over the end of the tube you'll see that you will need quite a bit of flare just to get past that hole. I also made a tool to compress the rubber and inner portion of the bushing in order to get the washer on the tube properly.
I'll post some pics of the tools I made tomorrow if that helps.
Steve g
To Trailing arm bushing install question.
